Old 08-15-2024, 07:20 AM   #1
Tippen48
Default Towing
Hello !
If my car stops , how do i tow , where do i put the towline on the car ? I think i must put a towe eye in the front some where ! Is there anybody that made one on there car ? Will be glad for a tip !
Tippen48 is offline   Reply With Quote
Old 08-15-2024, 08:34 AM   #2
GB SISSON
GB SISSON's Avatar
Default Re: Towing
I have always attached a tow line to the front axle. A nylon strap or heavy rope is far better than a steel chain or cable as it has shock absorbing stretch.
Old 08-15-2024, 09:42 AM   #3
glennpm
glennpm's Avatar
Default Re: Towing
For a beam axle it's not advisable to chain or strap in the middle of the beam axle. It is too easy to bend it there. Two straps just outboard of the the radius rods are best.
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 08-15-2024, 01:58 PM   #4
ford38v8
ford38v8's Avatar
Default Re: Towing
Here Here! Yes, and be aware that tow truck drivers are generally not going to follow this advice unless you point out that danger to them. Insist that they do not use the center of the axle to pull the car onto the flatbed, but to use the side or both sides of the axle only.
Alan
Old 08-15-2024, 02:23 PM   #5
trulyvintage
trulyvintage's Avatar
Lightbulb Re: Towing
Originally Posted by Tippen48 View Post
Hello !
Check your automobile policy
to see if you have towing coverage.
If you don’t then see if you can
add it.
If you don’t already have it
consider buying a
AAA Premier Membership.
Flat towing a vehicle is dangerous
for the driver of the tow vehicle
and the driver of the passenger vehicle
and fellow motorists - you may also
cause damage to the tow and towed
vehicles.
Jim
trulyvintage is online now   Reply With Quote
Old 08-15-2024, 03:10 PM   #6
Bruce of MN
Bruce of MN's Avatar
Default Re: Towing
I carry axle straps in the trunk for the tow truck driver to use.
Old 08-15-2024, 03:11 PM   #7
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Towing
I don’t think AAA has a plan that works in Sweden.
As shown above the front axle at the spring perch is a good place for a strap
Old 08-15-2024, 03:22 PM   #8
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Towing
Hello !
The picture (BELOW) shows one example of how a Ford I-beam can be bent by towing other than GLENN's circled (accepted) method at the perch pin.
Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 08-15-2024, 03:52 PM   #9
trulyvintage
@ https://exchange.aaa.com/internation...ational-clubs/
Jim
Old 08-15-2024, 08:10 PM   #10
Flathead Fever
Flathead Fever's Avatar
Default Re: Towing
glenpm's excellent photo shows you the perfect spots to toe an old Ford from with the least chance of bending something. Carry a quality tow strap already fabricated up to tow from those from these two spots, just in case you need it or maybe somebody does.
Old 08-15-2024, 08:55 PM   #11
19Fordy
19Fordy's Avatar
Default Re: Towing
This is a request for a Fordbarner to post information about which is a good tow strap to use and carry in trunk of car. Thanks. Jim
Old 08-15-2024, 09:53 PM   #12
GB SISSON
GB SISSON's Avatar
Default Re: Towing
Perhaps this is why I'm forever readjusting the toe-in on my trucks.... Thanks for the tip.
Old 08-15-2024, 10:07 PM   #13
trulyvintage
Post Swedish Towing Laws
Swedish Towing Laws:
@ https://www.ikorkort.nu/en/theory/bi...ra.php#bogsera
Jim
Old 08-16-2024, 12:36 PM   #14
glennpm
glennpm's Avatar
Default Re: Towing
First, thanks Coop for the bent beam axle photo.
I posted above where a strap, cable or chain should be located to prevent bending beam axles. I had to get towed about three weeks ago when I broke down with a bad new condenser :-( While waiting for AAA showed up, I started thinking about carrying a strap/s like I do with my motorcycles. Luckily the operator really liked my car and between us, located an old towel he had and I wrapped the front axle outboard of the perch bolt and we easily got it loaded. Because of where I was located, it had to be pulled from the front.
If a longer reach on the straps is required. the two eight footers could be linked with a square knot end to end to give you about 15" on one side.
This morning I was searching for good options, not for flat towing, but a safe way to get my '32 onto a flatbed. My first choice would be to pull up from the rear using the stout rear axle. But from either direction I wanted fairly short straps to carry all the time. I ended up purchasing Two 8' long straps:
https://www.amazon.com/dp/B00Z8R7T3Q...p_imgToDp&th=1
Regarding,
Hello !
If my car stops , how do i tow , where do i put the towline on the car ? I think i must put a tow eye in the front some where ! Is there anybody that made one on there car ? Will be glad for a tip !
You could fabricate a thick plate with four holes matching the front spring bottom plate retainer bolt pattern and weld a hook onto the plate. You would need longer spring U-bolts. Maybe longer Ford truck U-bolts could be used or go to a spring fabricator and have some made.
Glenn
Rumble Seat’s Notes
Old 08-16-2024, 08:19 PM   #15
paul2748
paul2748's Avatar
Default Re: Towing
I joined AAA and use a flatbed if I break down.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 08-16-2024, 09:30 PM   #16
51504bat
51504bat's Avatar
Default Re: Towing
Even with a flatbed the cable still needs to be hooked up to get the car onto the flatbed. Hooking up to the center of the axle probably wouldn't be an issue but why take a chance. Best to use a harness connected to both sides of the axle near the spring perches. JMO
Old 08-16-2024, 10:22 PM   #17
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Towing
I need to come up with a book explaining the diverse subject of forces.
Coop
T5 W/TORQUE TUBE
Old 08-17-2024, 01:53 AM   #18
cas3
Default Re: Towing
I've hooked on to the center of the axle plenty of times with no issues. Depends...are you stuck in mud up to the running boards, or just flat towing a few blocks to get home on a paved road. Then, it has a big effect on who is doin the towing.
for example, my friend who has a C Allis tractor with a loader on front, got stuck in a snow bank, and had the wife pull him out with the pickup. They hooked up a chain, with plenty of slack, she thought it best to floor it to make sure it was a success, ripped all the ears off the block where it connects to the rest of the tractor. He said, one minute he was sittin on his tractor, the next minute, after the big bang he was lookin at the ground! Moral of the story, hook on the center to move the thing. have a qualified operator doing the towing and you will not have a problem. done it many times myself
Old 08-17-2024, 12:52 PM   #19
flatford8
flatford8's Avatar
Default Re: Towing
I use one like Glenn showed, only mine has a hook on one end……when I used to pull a flatbed trailer truck, I was always finding broken/ torn nylon straps, and seeing how I just can’t throw something away, I’d just tie a loop in each end…..Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
flatford8 is online now   Reply With Quote
Old 08-17-2024, 12:57 PM   #20
glennpm
glennpm's Avatar
Default Re: Towing
Be careful with those that have a hook or turnbuckle on the strap. They can become a lethal projectile if the strap breaks! When searching for straps yesterday, there was one incident reported where a father and son were both killed this way.
Glenn
