I have some new (to me) tools that maybe someone might recognize. You can look at the in my tools album user cp photos. Or if someone more IT savvy could attach them to this post.
Cheers, Jim&Sandy McGregor, IA |
As requested
Thank you 51504bat!
valve compression bar, couple of valve keeper tools, piston ring groove cleaning tool, + a couple I do not recolonize.
Thanks Terry. So the long bar is for installing the valve and guide into the block, that’s what I thought. And a couple of valve spring compressors to install the keeper. No idea what photo 7 (counting left to right) is?
bigger pics in the album. Click on each image.
https://www.fordbarn.com/forum/album.php?albumid=5868 No7 does look like a ridge reamer. |
Ridge reamer as in top of the cylinder ridge?
yeah
I’ll get some better pictures of it.
I added a few more pictures and I see of it! Indeed it is a cylinder ridge reamer and I understand how it works. It came in a metal box with a New Britain label. Also in the box were another set of cutters for larger bores and three more tabs to position the cutter on the block.
