idle about 1 pound motor sounds good does not smoke at all
A Ford flathead requires very little oil pressure. A showing on your gauge should put a smile on your face.
Alan |
Whats cold pressure? And what oil are you using ?
Any Oil pressure is good -The Chex Accessory combined Ammeter/Oil Pressure gauge I have reads "" Yes " or "No" for Oil pressure
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me. |
I can tell you, if any of my flatheads idled at 1 psi I would be worried
Lawrie |
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
Not knowing how long this has been going on or any of the other variables I'd start with a known good mechanical gauge. JMO
#8 | |
And GB, I'd check the restrictor fitting; it may have been homemade by someone with a minimal selection of drill bits. |
oil gauges are indicators nothing more, Check where your gauge sits at a range of rpm and sump temps with a good quality test gauge and that should tell the story mine reads 15psi on the dash but a test gauge reads 25 and so one thru the range so Nil to worry about A sudden change would ring alarm bells
