Old 07-13-2024, 03:45 AM   #1
FrankWest
FrankWest's Avatar
Default NO Spark
1933 model b
replaced coil and condenser
When starter is activated car ammeter jiggles, but have no spark at plugs
I am getting so old and confused, need help
FrankWest is offline   Reply With Quote
Old 07-13-2024, 04:07 AM   #2
deuce lover
deuce lover's Avatar
Default Re: NO Spark
Do you have current to the coil? When you touch the red and black multimeter wires to each other ,do you get a reading? If so then to the each terminal of the coil ,does it register?
Old 07-13-2024, 05:49 AM   #3
Terry,OH
Terry,OH's Avatar
Have you cleaned the distributor points and checked point gap? Is the battery ground path good?
Old 07-13-2024, 06:47 AM   #4
FrankWest
FrankWest's Avatar
Is there a special trick in getting the rotor off to check the points? I thought the rotor will just pull off?
Old 07-13-2024, 06:54 PM   #5
A bones
A bones's Avatar
They can be stuck, keep coaxing. Careful of your hand when it does let loose.
Try a light tap tap tap while trying to raise it.
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
