Old 05-10-2024, 02:55 PM   #1
fordv8j
fordv8j's Avatar
Default Optima battery replacement
We have an 6 volt optima battery in a Ford script case, it is 10years old, thinking it will be needing replaced soon, how is the best way to get out of the case, through the top or bottom, or...its a 2HF--- Thanks, J R Parsons, WVa
fordv8j is offline   Reply With Quote
Old 05-10-2024, 05:31 PM   #2
tubman
tubman's Avatar
Default Re: Optima battery replacement
Generally, the top is a separate piece that should be removeable. I know mine is. Hopefully, the original owner didn't glue everything together.
Since his is a non-standard process, I'm afraid you can expect anything. Give it a good lookover and maybe you can detect what was done.
Old 05-10-2024, 05:35 PM   #3
fordv8j
fordv8j's Avatar
I ordered it new, like that
Old 05-10-2024, 05:50 PM   #4
tubman
tubman's Avatar
Hmmm. OK; I made my own. In your case, I stand by the second paragraph of my last post.
Old 05-12-2024, 12:18 PM   #5
Ken/Alabama
Ken/Alabama's Avatar
The top will come off. You’ll need to trim the plastic away from the post .
Old 05-12-2024, 01:10 PM   #6
slowforty
If you get a battery through Amazon and get a credit card they will give you a $100 off
slowforty is offline   Reply With Quote
Old 07-09-2024, 07:22 PM   #7
philipswanson
Anybody know who is making the Ford case that takes the Optima battery these days? I couldn't get in touch with the old supplier.
philipswanson is offline   Reply With Quote
Old 07-10-2024, 08:07 AM   #8
Pat/Ohio
Pat/Ohio's Avatar
You might try C&G in California. It will take about 3 or 4 months to get delivery. They are custom made to order.
Here is a reply to my last email for them:
Yes we do = https://cgfordparts.com/catalogsearch/result/?q=OPT-2HF
The battery is made to order and usually take 3 to 4 months for delivery. Shipping is extra.
The battery has to be ordered over the phone since it is a special order.
Thank you,
C&G Early Ford Parts
1941 Commercial St
Escondido, CA 92029
(760) 740-2400 (ph)
(760) 740-8700 (fax)
www.cgfordparts.com
Pat
Pat/Ohio is offline   Reply With Quote
Old 07-10-2024, 01:34 PM   #9
AWS3OldFords
If one wanted to buy a 6 volt battery for a 34 Ford and was not concerned about original appearance, what amount of CCA should one look for? Any info. on how many CCA Ford had in their batteries back in 1934? Does anyone know the rating of the wire that goes from battery to starter, e.g. 4 awg or 2 awg or something else?
Any info would be appreciated.
AWS3OldFords is offline   Reply With Quote
Old 07-10-2024, 04:51 PM   #10
Firechickenzz
Firechickenzz's Avatar
I just ordered this. $41 shipped. Tar Topper
Firechickenzz is offline   Reply With Quote
Old 07-10-2024, 04:52 PM   #11
Firechickenzz
tartopperdotcom
Old 07-10-2024, 05:50 PM   #12
petehoovie
petehoovie's Avatar
Originally Posted by Firechickenzz View Post
tartopperdotcom
https://www.tartopper.com/product/op...eptember-2018/
Old 07-10-2024, 06:11 PM   #13
Firechickenzz
That's the one. I didn't have enough posts to include links yet. I should now.
Old 07-10-2024, 08:33 PM   #14
philipswanson
I was thinking about the one with the Ford logos on the sides like Kirk White used to sell. His phone is not working.
Old 07-10-2024, 08:47 PM   #15
tubman
tubman's Avatar
That looks like it's specifically for 12 volt conversions. The posts are in the wrong place. I wonder if a 6 volt Optima would even fit without a bunch of changes.
Old 07-10-2024, 09:26 PM   #16
47Monarch
47Monarch's Avatar
I use welding cable for my ground straps works great and last forever⁶
47Monarch is offline   Reply With Quote
Old 07-11-2024, 07:35 PM   #17
philipswanson
The one Kirk White sold housed a 6 volt Optima perfectly with terminals on the proper side. Got one in my 40 wagon and 51 Victoria. Need one for my 51 wagon.
Any body know what happened to him? His phone rings and rings.
Phil Swanson
Old 07-13-2024, 04:09 PM   #18
Ford46
Ford46's Avatar
Kirk White passed away several years ago.
Ford46 is offline   Reply With Quote
Old 07-16-2024, 10:01 PM   #19
philipswanson
So sorry to hear that.
