Old 07-05-2024, 02:36 PM   #1
BoxCar Tom
BoxCar Tom's Avatar
Default Early 32 Ford?
These holes in my front splash pan on my early SN 32 Sedan always make me wonder. The holes in front of the cross tube are stock but not used. The two behind? Early version? later modification? Also it appears that original splash pan hardware was used in the correct location but in reverse order. ??????
BoxCar Tom is offline   Reply With Quote
Old 07-05-2024, 03:16 PM   #2
deuce lover
deuce lover's Avatar
Default Re: Early 32 Ford?
Appears that it was reassembled by someone that put the front bumper iron bolt in the rear.Not supposed to have the hole behind the bar I don't think. How early is your sedan?
Old 07-05-2024, 03:31 PM   #3
BoxCar Tom
BoxCar Tom's Avatar
SN is between 18-6800 and 6850
Old 07-05-2024, 05:20 PM   #4
petehoovie
petehoovie's Avatar
Old 07-05-2024, 05:29 PM   #5
DavidG
DavidG's Avatar
Tom
I agree with Sheldon. All earlier that I have had were fastened the same as mid-year and late production.
The only difference between the early aprons and all those that followed is the addition of a hole in the bottom lip of one side to permit the apron to be attached to a conveyor (according to the engineering drawing for the apron).
Old 07-06-2024, 10:27 AM   #6
BoxCar Tom
BoxCar Tom's Avatar
Thanks for the replies. Someone in the distant past went to a lot of trouble to precisely add those two extra holes and also reuse original hardware in an unorthodox application. What was the motivation? This effort was contradictory to the way the driveline was maintained. The engine compartment contained a generous serving of period household carpentry, electrical and plumbing fixes. It was a work of "art" in deep contrast to those two extra holes.
Old 08-28-2024, 08:33 PM   #7
Deuce Bob
Deuce Bob's Avatar
Tom call me I want to get this 32 block out of my way thanks Bob 203-331-7234
Deuce Bob is offline   Reply With Quote
