Old 06-30-2024, 01:19 PM   #1
Babyboomerboy
Babyboomerboy's Avatar
Default Which direction does the trunk seal face?
I am trying to figure out which way to install the weather seal on the trunk of my 50 ford.
https://www2.dennis-carpenter.com/in...8A-7043720.pdf
https://bobdrake.com/products/1949-5...ZjjHs#images-2
As you can see they each face a different direction. Which one is correct? Thank you
Babyboomerboy is offline   Reply With Quote
Old 06-30-2024, 02:04 PM   #2
19Fordy
19Fordy's Avatar
Default Re: Which direction does the trunk seal face?
Unless my eyes are fooling me both diagrams are the same re: trunk seal install. Flatside glued to tunk lid with curved tip pointing toward car exterior.
https://shoebox-central.com/1949-195...stripping-seal
Old 06-30-2024, 06:10 PM   #3
Babyboomerboy
It appears to me that the first picture, the curved part points to the inside of the car and the second picture shows the curved part pointing to the outside of the car.
Old 07-01-2024, 10:18 AM   #4
19Fordy
19Fordy's Avatar
Yes, I think you are correct. My assertion appears incorrect. It would be great if someone could post a "real time" photo of how their seal is installed.
If not, cut off a small length of new seal and experiment to see which position seals and fits the best.
Old 07-01-2024, 08:10 PM   #5
joe 1950
joe 1950's Avatar
when i did mine i put it like the Dennis Carpenter diagram it never leaked
joe 1950 is offline   Reply With Quote
