What condenser do I use for a model b 1933 engine
Try Renner's Corner.
Thanks David. He does not have them, But I found one at allfordparts. Hope it works.
Never realized this was a unique part for model B. I wonder why model A condenser will not work on model B. I could understand why a v8 condenser will not work. These cars are more complicated than I once thought. |
Many condensers can work on a model b ford it just won't look right.
#5 | |
Charlie Stephens Last edited by Charlie Stephens; 06-27-2024 at 05:47 PM. |
#6 | |
Charlie,
What's truly ugly are the way-too-long head studs.
NOS B condensers aren't very scarce and in my experience work as intended despite their age.
Thanks. Good to know.
Here is a photo of my existing condenser and mounting. I don't know if it is the proper original configuration?
#11 | |
Yours is located as original.
#13 |
wow, beautiful restoration
#14 |
#15 |
I believe this is what you want B-12300, 0.20 to 0.25 mfd about the same rating as the 46-48 6 Cyl condenser which may be offered by NAPA, but it would not have the mounting bracket.
#16 | |
#17 |
If it fits the hole you could epoxy the old mounting bracket on it.
#18 |
The mounting bracket is an electrical conductor Suggest soldering it on to another condenser, if need be.
#19 |
Try the Model a suppliers like Snyders, Brattons, etc. since many Model A's are running B engines.
#20 |
