I has the same set up but not running it yet.
Its both in 9 and 10 inch. I has the 10”. Idea was a light pressuare plate. Compare weight from steel flywheel and a std steel pressuare plate its a big weight reduction. Not all combos might like a light set up like that. I think this was tractor parts (?) For me it feel old hot rod. -One told me its a weak plate and nothing to use 2024. But I saw it old school ideas they might used. I will has a light car and heavy ported block, rather high compression, dual carbs, Potvin 425 cam, 4.44 rear, 2.21 first gear and 31.5” tall tires and crank is also ligher. This was my idea, but guy run it might can tell more on how it works in reality. Last edited by 3W Hank; 06-21-2024 at 06:51 AM. |
