Thought I would share what I measured on my build.
C59A Stk crank 0.060 over (Egge pistons) C7RA-A cast iron factory Ford heads Felpro head gasket - 0.055 thk NGK sparkplugs Block and heads were skimmed (not sure how much), but it was just to clean them up Heads were tightened to spec Head to piston clearance - 0.073 Sparkplug to exh valve clearance - 0.128 (valve closed). |
