Old 02-04-2024, 06:01 PM   #21
scicala
scicala's Avatar
Default Re: "lil red" 1965 Mercury Comet Caliente
All this talk and pictures about the Comet, with no mention of which engine is under the hood, other thn a picture of 8 dirty spark plugs and a right side exhaust manifold.
So, I assume it's a 289, but which one ? Two barrel or 4 barrel ?
Sal
scicala is offline   Reply With Quote
Old 02-04-2024, 10:13 PM   #22
sugarmaker
sugarmaker's Avatar
Sal, folks,
Yes this Comet has a 289 with stock 2V carb. It does have duals and glass packs. Also has C4 auto transmission. (information hidden in post number 1)
Regards,
Chris and Cheryl
1932 AAB Truck
1953 Ford Jubilee
2015 Ford F250 SuperCrew
Lots of Allis tractors
Some Cub Cadets
Old 02-20-2024, 07:31 PM   #23
sugarmaker
sugarmaker's Avatar
Folks,
We have been tuning and testing and learning about the 2 barrel carb on the Comet. Good instructions have helped get the choke settings much closer. The car is starting better, and not stalling.
Adjusted the trunk and hood. Some new parts coming to help clean up some details.
Regards,
Chris and Cheryl
1932 AAB Truck
1953 Ford Jubilee
Some Cub Cadets
Old 02-20-2024, 08:01 PM   #24
rjlester
Finally read thru this thread. Congrats on a great car! You've made some nice improvements and it looks fantastic.
rjlester is online now   Reply With Quote
Old 02-20-2024, 08:24 PM   #25
sugarmaker
sugarmaker's Avatar
rj,
Thanks! The seat refurbishment will be a large project for the car this spring. New foam and improved seat springs for the front buckets too. I didnt realize these seats were so worn and sagging. They have been covered once in material that matches the original style very well. The plan is to reuse the current covers.
Regards,
Chris and Cheryl
1932 AAB Truck
1953 Ford Jubilee
Some Cub Cadets
Old 03-08-2024, 10:25 PM   #26
sugarmaker
sugarmaker's Avatar
Ford Barn folks,
New seat foam and the right back up light lens:
John helped look at the lens today.
Old:
new:
Regards,
Chris and Cheryl
1932 AAB Truck
1953 Ford Jubilee
Some Cub Cadets
Old 03-09-2024, 11:20 AM   #27
KULTULZ
KULTULZ's Avatar
You know, a 64/65 COMET (the 65 more so) were beautiful cars.
Those MAGNUM wheels really set it off.
Tell that lovely wife of yours I said she looks sixteen again behind that steering wheel ...
KULTULZ is offline   Reply With Quote
Old 03-10-2024, 10:18 AM   #28
5851a
Very nice, great colors. Nice lenses too.
5851a is offline   Reply With Quote
Old 03-20-2024, 08:56 PM   #29
sugarmaker
sugarmaker's Avatar
KULTULZ, 5851a,
Thanks for the positive comments. Cheryl would be tickled! We have been together since we were kids. The Comet may help us relive a few of those memories.
We are doing an oil change, filter, and maybe fuel filter change also. Then carb rebuild and the seat project. We hope to be ready for spring car cruises.
Regards,
Chris and Cheryl
1932 AAB Truck
1953 Ford Jubilee
Some Cub Cadets
Old 03-30-2024, 09:19 PM   #30
sugarmaker
sugarmaker's Avatar
Ford Barn folks,
The Comet project is moving along nicely.
Changed the oil and filter. Also changed the fuel filter canister.
The seats are being reupholstered, improving the spring system and new foam. Also going to move the seat back a couple inches and try it.
Carb has been rebuilt with new gaskets and a good cleaning. The car is running much better on several starts:
Adjusted the drivers door latch post on the door jam just a smidge. Working like a new one!
In the shop living room for a needed bath.
Regards,
Chris and Cheryl
1932 AAB Truck
1953 Ford Jubilee
Some Cub Cadets
Old 03-31-2024, 10:02 AM   #31
Oldmics2
Nice car
Oldmics2 is offline   Reply With Quote
Old 04-02-2024, 09:01 PM   #32
slumlord44
Love it. I’ve had 3 65’s over the years back in the day. I had both a Calante and a Cyclone. Am I wrong or is this a Caliente with a Cycone interior? I’m not criticizing just relating my experience.
slumlord44 is offline   Reply With Quote
Old 04-03-2024, 06:04 AM   #33
Jeff Norwell
Jeff Norwell's Avatar
That is one beautiful Merc. Just Lovely.
Jeff Norwell is offline   Reply With Quote
Old 04-05-2024, 07:15 AM   #34
Greg Rogers
Greg Rogers's Avatar
Love that car!!
Greg Rogers is offline   Reply With Quote
Old 04-05-2024, 08:23 PM   #35
sugarmaker
sugarmaker's Avatar
Oldmics2, slumlord 44th, Jeff, Greg, Folks,
Mic,
Thanks for the compliments on the old Comet.
Slumlord 44th,
I believe that the interior is correct factory buckets and console from the factory.
Jeff,
Thanks! Wow you do amazing work! Might need a Comet drawing added to your works too! Just saying.....
Greg,
Thanks, We have talked somewhere?? Maybe on the 32??
Update on the Comet:
cleaned up the back of the center console
The wood insert is my own creation. Black Walnut shaped to fit in where the unobtainable plastic insert went.
Had new foam installed over the old springs and under the old covers. Local shop did a nice job making this happen and look good in a couple weeks. Seats are now much more supportive. Spring was broke and repaired.
I made custom rails to set the seats rearward 3 inches. Rails can be removed to return seats to stock positions.
Re stripped the arm rest and painted it again with SEm white.
Installed a repro mirror on the passengers door today. I even moved it back from the more correct position so I could see out of it:
Regards,
Chris and Cheryl
1932 AAB Truck
1953 Ford Jubilee
Some Cub Cadets
Old 04-23-2024, 09:24 AM   #36
sugarmaker
sugarmaker's Avatar
Folks,
Continuing to make minor improvements to the 65. The carb needed the float reset, to allow more fuel in the bowl. That seems to allow it to run better.
Cheryl and I have driven to several local ice cream shops! It always gets looks and comments.
Yesterday I reworked the door weather strip that was falling off.
Also added a little brake fluid. Washed the exterior and Adam cleaned some of the chrome with a nevrdull polish.
Getting ready for car cruise ins, and several car shows.
My tractor events may take a back seat as I need to spend much more time with Cheryl.
Hope things are good in Ford land!
Regards,
Chris and Cheryl
1932 AAB Truck
1953 Ford Jubilee
Some Cub Cadets
Old 05-05-2024, 09:02 PM   #37
sugarmaker
sugarmaker's Avatar
Folks,
Several 50 mile rides with friends and to ice cream stops along the way too.
Still tuning but getting better and still learning!
Regards,
Chris and Cheryl
1932 AAB Truck
1953 Ford Jubilee
Some Cub Cadets
Old 05-06-2024, 08:02 AM   #38
RKS.PA
RKS.PA's Avatar
Chris, wonderful to see you and Cheryl out and about in Lil Red!!! Hoping she continues to do well...rides for ice cream certainly can't hurt anyone!!!
RKS.PA is offline   Reply With Quote
Old 05-10-2024, 03:40 AM   #39
sugarmaker
sugarmaker's Avatar
RKS.PA, folks,
The ice cream trips with lots of 50's music seem to be a good thing for both of us!
We have a car show in our little town this Saturday but the weather is not going to be great. So we may travel to the tractor plow day with the Allis D17 and two bottom Dearborn plows attached? Will try to get some pictures too.
I still feel that the Comet has a slight miss at various times. More checking and tuning required I guess?
Noticed differential leak on right rear wheel. Ordered seals and gaskets from NAPA for that project. Have never pulled an axle on a car before. So that should be fun.
John and I did manage to remove the chrome eyelids on the headlights. I think I like it better with just the full bulb look.
Regards,
Chris and Cheryl
1932 AAB Truck
1953 Ford Jubilee
Some Cub Cadets
Old 05-10-2024, 11:44 AM   #40
RKS.PA
RKS.PA's Avatar
Hi, Chris,
Pulling your right axle is no big deal compared with pulling one on John's coupe!!! At least I'm hoping that's the case for you!!!
By the way, you might pose a quiz on here to see how many of us know what a "two bottom plow" is. (I'm a farm kid and I know!!!)
Regards,
Dick.
