Old 04-29-2024, 06:02 PM   #81
Mart
Mart's Avatar
Default Re: What did you do today that was flathead V8 related?
Nice job, Rock.
Old 04-30-2024, 10:37 AM   #82
jplutz
jplutz's Avatar
Changed the oil & filter, installed new plugs, cut excess park brake cable( had to make my own rear cable set), cleaned off the auto trans id plate so I can order a new pan gasket. Started the engine and let it warm up. Everything done in the yard, up on Jack stands. Got my exercise, but my wife says I don't walk enough... I'll be 80 this fall. Ha Ha!! JPL
jplutz is offline   Reply With Quote
Old 04-30-2024, 11:02 AM   #83
rockfla
rockfla's Avatar
Originally Posted by Mart View Post
Nice job, Rock.
Thank you Mart, I had a great "teacher/example" to follow!!!
Old 05-01-2024, 05:41 PM   #84
fordv8j
fordv8j's Avatar
I woke our 38 convertible coupe up from a long winters nap; hooked battery up; put a little gas in carb,started right up, went for a warm up drive, aired up tires, and cleaned white walls; ready for AUburn
fordv8j is offline   Reply With Quote
Old 05-01-2024, 07:05 PM   #85
dean333
dean333's Avatar
Send a message via Yahoo to dean333
Bought another one!
Tim Carlig
dean333 is offline   Reply With Quote
Old 05-01-2024, 07:21 PM   #86
ndnchf
ndnchf's Avatar
The Luray pre-war swap meet is just over a week away. I've been working hard to get a batch of rebuilt generators and refurbished cutouts ready to bring. I just started on another batch of cutouts tonight.
This is one of the best small swap meets on the east coast. So who is going? I'll have my table set up at Wick's spot along the treeline. Stop by and say high.
Steve
ndnchf is online now   Reply With Quote
Old 05-01-2024, 09:35 PM   #87
dean333
dean333's Avatar
You do nice work, Steve.
Tim Carlig
Old 05-01-2024, 09:41 PM   #88
petehoovie
petehoovie's Avatar
Steve
Old 05-02-2024, 08:52 AM   #89
Als48
Luray's in Virginia, right?
Al Hook
Als48 is offline   Reply With Quote
Old 05-02-2024, 09:32 AM   #90
ndnchf
ndnchf's Avatar
Al Hook
Yes!
Old 05-13-2024, 04:22 AM   #91
ndnchf
ndnchf's Avatar
Nobody working on a flathead V8 lately? I just got back from Luray where I sold some '35 Ford parts and refurbished original Ford cutouts.
Old 05-13-2024, 05:14 AM   #92
Mart
Mart's Avatar
Just put some new front wheel cylinders on my 41 pickup. Rear ones will be done when the new ones get here.
Old 05-13-2024, 06:04 AM   #93
38 coupe
38 coupe's Avatar
Last week I helped swap the banjo section, ring & pinion, on a 40 pickup axle. The pins holding the coupler to the driveshaft and pinion had snapped due to worn out splines (the pins were taking the driving load and failed). We replaced the 4.11 with worn out splines for 3.78 with nice splines, good teeth, and nice bearings.
Old 05-13-2024, 09:27 AM   #94
petehoovie
petehoovie's Avatar
Old 05-16-2024, 03:40 PM   #95
ndnchf
ndnchf's Avatar
I just posted a new video about installing and seating generator brushes. The example is for a model A generator, but the same process applies to flathead V8s. Some of you may find it helpful. There are many other generator related videos on my youtube channel as well.
https://youtu.be/1NiBylwzJ2s?si=fo3ulDRBBsYXHjGw
Old 05-17-2024, 09:09 AM   #96
dorvedahl47pu
dorvedahl47pu's Avatar
Originally Posted by rockfla View Post
Good thread Steve
I am Slowly putting this one together to go into a "restoration" project in Holland via a restoration shop in Poland. Started to assemble this past weekend and working on it night by night.
What about a 1941 4cyl....is that allowed???
May I ask what you sprayed on the engine (looks like 2 different things) prior to applying the finish coat? Thanks.
Dale
dorvedahl47pu is offline   Reply With Quote
Old 05-27-2024, 04:28 AM   #97
ndnchf
ndnchf's Avatar
Must be a slow week...
Old 05-27-2024, 06:48 AM   #98
cadillac512
cadillac512's Avatar
My ol' flathead is just running so well that all I do is drive it! That reminds me-it's oil change time again.
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 05-27-2024, 11:47 AM   #99
tubman
tubman's Avatar
I just got back from Florida and found the battery in my '51 was dead (the battery tender somehow got disconnected when I let the hood down last fall). I hooked up an old style charger (the maintainer wouldn't start) and am hoping it'll come back. With the price of Optima's these day, I hope it's not kaput.
Old 06-03-2024, 06:25 PM   #100
ndnchf
ndnchf's Avatar
I just finished rebuilding this really nice, original paint 1940 generator. I'll be bringing it and other rebuilt generators and cutouts to the Richmond Virginia AACA meet this Saturday.
