Old 04-29-2024, 10:42 AM   #21
Planojc
Planojc's Avatar
Default Re: Opinion needed on fuel pumps
Electric fuel pumps are a must here in the hot summers of Texas where vapor lock is common.
Planojc is offline   Reply With Quote
Old 04-29-2024, 02:14 PM   #22
drolston
drolston's Avatar
Ditto, even in Virginia. On hot days in traffic, my '41 will vapor lock while running on 10% ethanol fuel. My pump switch has a momentary position for priming, but on those days it goes to the "ON" position.
Old 04-29-2024, 05:09 PM   #23
Merc Cruzer
Merc Cruzer's Avatar
Just in case you are looking for a flow through pump:
https://www.amazon.com/AUTOKAY-Elect...ive,118&sr=1-5
Merc Cruzer is offline   Reply With Quote
Old 04-29-2024, 06:54 PM   #24
dean333
dean333's Avatar
Send a message via Yahoo to dean333
It gets pretty hot in the Chicago area in the summer. I don’t get the vapor lock problem if your car is functioning properly.
Tim Carlig
dean333 is offline   Reply With Quote
Old 04-29-2024, 07:58 PM   #25
Vanspeed
Vanspeed's Avatar
Originally Posted by ford38v8 View Post
A schedule of starting an engine, say, once a week, running it at idle till it warms up, doing this during a storage period of a year or more, sounds good so you can sleep well. Truth is, you’re not doing any good at all, and in fact, you’re harming your engine, your exhaust system, your tires, your battery, and your brake system unless you have mechanical brakes. A car needs to be driven, not just start up and idle.
I understand but in northern Michigan that is not an option unless you’re lucky. Salt on the roads, snow, slush, etc. A start up now and then during the winter has never hurt any of my flatheads.
Respecting and Resurrecting Ford Model A's.
Vanspeed is offline   Reply With Quote
Old 04-29-2024, 08:00 PM   #26
Vanspeed
Vanspeed's Avatar
The owner told me today it ran better without the pump, it was still hard to start however. A carb rebuilt, new mechanical pump and what needs to be done to take it back to factory was given the thumbs up. I will keep you posted.
Old 04-30-2024, 01:32 PM   #27
Fritz
Fritz's Avatar
Chicago never gets Texas hot. It sometimes gets TN and VA hot.
For what it’s worth, I’ve only used an airtex 6v pump for the last 10 years. It works excellently. Maybe it was a bandaid when I installed it, but after chasing out all the gas and electrical bugs, it works great.
Cars and metal rust away and are destroyed, but the Word of God will stand forever (Isaiah 40:8, Matthew 24:35).
Fritz is offline   Reply With Quote
Old 04-30-2024, 05:46 PM   #28
petehoovie
petehoovie's Avatar
Originally Posted by Lawrie View Post
Another thing to do is fit a pump with a priming lever,they are around,mostly on UK and NZ cars,
Lawrie
Old 04-30-2024, 07:07 PM   #29
kiwi nz
kiwi nz's Avatar
Thanks Pete, yes I have one of those somewhere, I didn't realise that it was a mostly UK, NZ. All our NZ assembled cars came from Canada, maybe it is a Canadian made pump.
Geoff Kiwi
kiwi nz is offline   Reply With Quote
Old 05-01-2024, 01:12 PM   #30
John Gibson
John Gibson's Avatar
If either the 33 or the 36 sits for more than a few days the carburetor will be dry out here in SE Georgia. I use a spray bottle filled with 50 to 1 small engine fuel from either Lowes or Home Depot. Usually takes three squirts before pump fills the carburetor. Quicker if I have someone else to help me out. Stock pumps at 2 1/2 lbs pressure work just like Henry intended them to do.
John
John Gibson is offline   Reply With Quote
Old 05-06-2024, 04:58 PM   #31
Vanspeed
Vanspeed's Avatar
The car is all buttoned up and back together using a mechanical pump from 3rd gen automotive. The pushrod was missing so I had to procure one of them as well. Thanks for all the replies.
