Old 04-23-2024, 11:57 AM   #1
cpldale
cpldale's Avatar
Default Brake drum question
I bought what I was told were 46-48 front and rear brake drums with hubs. The drums were out of spec so I used a 5/8 hole saw to remove the the studs and separate the drums from the hubs. So far, so good. I went to order replacement drums and realized the center hole in the replacement drum is 3 1/4". The center hole in the old drums is 4". Not sure what I have. Any thoughts?
cpldale is offline   Reply With Quote
Old 04-23-2024, 12:48 PM   #2
Mart
Mart's Avatar
Default Re: Brake drum question
On earlier hubs and drums the drum fits over the hub. On later assemblies the drum fits on the inside of the hub. The drums are different. I think the early ones have the smaller ones and the later ones have the larger hole.
Old 04-23-2024, 01:23 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
There is NO workable replacement for the late style ('42 - '48) brake drums which fit INSIDE the hub. Only reasonable replacement consideration is Boling Bros. early drum mounted on an early hub, which is dimensionally viable to replace the later version.
Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 04-23-2024, 03:45 PM   #4
Ggmac
Good to see you here Coop !
Old 04-23-2024, 07:48 PM   #5
V8COOPMAN
V8COOPMAN's Avatar
Thanks, Bud! I'm moving along one day at a time here.
DD/Coopman
T5 W/TORQUE TUBE
Old 04-23-2024, 10:51 PM   #6
T Scott
An option, although maybe a little late in your case, is to have the drums relined and brought back within specification. J&G Relining in Mc Henry, IL. are the guys for this kind of thing.
T Scott is offline   Reply With Quote
Old 04-24-2024, 05:13 AM   #7
Mart
Mart's Avatar
Ecklers have the later drums but holy --- they are expensive.
Old 04-24-2024, 11:40 AM   #8
V8COOPMAN
V8COOPMAN's Avatar
Don't get me started about Ecklers. My peev with them goes back to the early 1990s with Corvettes. They're in it for the money, and good at that, for sure!! No improvement since that time. Example - the "Mac's" fiasco.
Coop
T5 W/TORQUE TUBE
Old 04-24-2024, 01:21 PM   #9
Randy in ca
Randy in ca's Avatar
Good to know anyways that they are at least available now. Maybe won't be long before others are selling them and maybe at a lesser price.
Anybody know who they're made by? Anybody tried them?
Randy in ca is offline   Reply With Quote
Old 04-25-2024, 08:21 PM   #10
30Murray
C&G Ford parts has the drums.
30Murray is offline   Reply With Quote
Old 04-26-2024, 02:44 PM   #11
V8COOPMAN
V8COOPMAN's Avatar
C&G has a bolt-on replacement drum for the '46-'48 drum on '46-'48 hub?
Coop
T5 W/TORQUE TUBE
Old 04-26-2024, 03:02 PM   #12
rich b
rich b's Avatar
Coop
They do and at a better price than Eklers; but curious about where they come
from (Argentina?) and if they more accurately machined than the ones that
were available previously.
https://cgfordparts.com/rear-brake-d...ml#description
Old 04-27-2024, 02:53 AM   #13
Randy in ca
Just today discovered that Bert's in Denver also has them listed for a much lower price ($150) than the others above:
A-2520-B BRAKE DRUM CAST IRON USA MADE 1942-1948 FORDS
The picture they show with these is the same generic one as shown for the 40-41's they show a different part number for. They're not open until Tuesday now when I'll try to confirm that these have the correct 4" center opening.
https://modelastore.com/hydraulic-br...oduct_id=18538
Old 04-27-2024, 01:00 PM   #14
V8COOPMAN
V8COOPMAN's Avatar
Hurray for Bert's! It is disgusting the number of folks that don't mind hiking the price of a simple part by $100 or more beyond what is necessary to cover costs and make a small profit ..... A sorry lot!
Coop
T5 W/TORQUE TUBE
Old 04-29-2024, 05:50 PM   #15
Randy in ca
Got an email back from Steve at Bert's today:
"Yes, these 42-48 drums have 4" hole for use with hub mounted on the outside of the drum, unlike earlier ones mounted behind the drum".
Steve
Old 04-29-2024, 06:43 PM   #16
65f100
65f100's Avatar
do these drums and hubs need to be held together same as the model A
65f100 is offline   Reply With Quote
Old 04-30-2024, 12:56 PM   #17
cas3
I will guess that the studs hold the drum on the hub as originally done with the drum behind style. I have one car with the early 40 style drum over the hub that I can run the drum loose as like a modern car does with no trouble
Old 05-01-2024, 12:32 AM   #18
Randy in ca
Bert's also lists splined studs to use with the 4" center hole drum. Not mentioned whether the stud holes need to be reamed a little larger or if they're correct as is. Alternately one can use the original style of studs which would need swaging to hold them in place.
