Old 04-19-2024, 02:11 PM   #1
hammondite
Default Flathead 8 and power brakes.
Howdy all.
I have a 30 Model A I bought off an estate a while back. The owner was going for a 50's 'ish' build.
Why am I here rather than the Model A forum? The car came with a 48 truck flathead V8 (that's why i bought it) and a Speedway brake/clutch master cylinder kit. Which has a power master cylinder.
Question - Can the flathead provide enough vacuum for the master cylinder? If so, are there any tricks/mods needed to do so, or can I just run the vacuum from the intake manifold?
hammondite is offline   Reply With Quote
Old 04-19-2024, 02:18 PM   #2
paul2748
paul2748's Avatar
Default Re: Flathead 8 and power brakes.
Really need a power brake with a Model A/flathead combo
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 04-19-2024, 02:26 PM   #3
Angledrive
Angledrive's Avatar
I would not use engine vacuum. If 12volt car use this..........
https://www.summitracing.com/parts/h...RoC1hgQAvD_BwE
Angledrive is offline   Reply With Quote
Old 04-19-2024, 03:33 PM   #4
petehoovie
petehoovie's Avatar
Hella Street Vacuum Pumps 009428087
Old 04-19-2024, 03:50 PM   #5
shoe box Jack
thank you petehoovie,
shoe box Jack is offline   Reply With Quote
Old 04-19-2024, 06:51 PM   #6
tubman
tubman's Avatar
I'm curious; what is your reasoning behind this statement?
A good running flathead makes plenty of vacuum (>20 inches). Is there a difference between 6 volt vacuum and 12 volt vacuum?
Old 04-19-2024, 10:05 PM   #7
Randy in ca
Randy in ca's Avatar
In the "notes" section for the above pump it states:
"This is not designed for use with power brakes; it is designed to control vacuum operated accessories. If used in conjunction with power brakes, it may not be sufficient as the main vacuum source".
Summit has other pumps recommended for use with power brakes:
https://www.summitracing.com/parts/a...9308?rrec=true
I kind of agree with tubman above - what vacuum is your engine producing?
No matter which way you go, the use of a vacuum reservoir (lots of different ones available) is a good idea in my opinion.
Randy in ca is offline   Reply With Quote
Old 04-20-2024, 01:17 AM   #8
aussie merc
aussie merc's Avatar
add a vac tank even ford supplied these as an accessory
aussie merc is online now   Reply With Quote
Old 04-20-2024, 08:11 AM   #9
Merc Cruzer
Merc Cruzer's Avatar
Yours is a 48' engine and mine is s 53', but yes the flathead provides enough vacuum for a power brake system. Mine is a factory Treadle-Vac, power brake booster, with a factory vacuum tank, under the driver side floor, bolted to the frame.
If you are still 6 volt pos ground you can always find and install an Electro-Vac unit.
Merc Cruzer is offline   Reply With Quote
Old 04-20-2024, 09:35 AM   #10
petehoovie
petehoovie's Avatar
Old 04-20-2024, 09:44 AM   #11
Ol' Ron
Ol' Ron's Avatar
I only saw one that comes to mind. It was on a 52/3 ford and had an adapter under the carb with a larh (1/2") line to the master cylinder vacuum unit. Not sure how it worked, it waz along time ago!!
Gramps
Old 04-20-2024, 11:11 AM   #12
hammondite
Thanks everyone.
The car was converted to 12v Neg ground, so it looks like, if needed, one of the aftermarket units should work. I'll check the engine vacuum first.
Old 04-20-2024, 01:22 PM   #13
Merc Cruzer
Gramps
This is how mine is routed, from the back the manifold, to the booster, on my 53' Merc, with a check valve at the booster. The last picture shows the hose coming from the vacuum tank mounted under the car.
Old 04-20-2024, 02:15 PM   #14
cas3
That sure is a tidy lookin engine bay there Mr Merc Cruzer !
Old 04-20-2024, 02:55 PM   #15
Merc Cruzer
Thank you, then goal accomplished.
Old 04-20-2024, 04:29 PM   #16
petehoovie
petehoovie's Avatar
Old 04-20-2024, 05:08 PM   #17
Ggmac
Check the amps required to run an electrical vacuum pump . I would just run the engine vacuum with a extra holding tank. Easier and probably cheaper . Just my opinion.
Old 04-22-2024, 10:59 AM   #18
hammondite
Thanks everyone for the answers.
I'll check the vacuum and decide whether to use a tank, pump or both.
