03-29-2024, 11:25 AM | #21 |
Re: 2024 video releases from Mart's Garage. All in this one thread.
Thanks Al.
57 T-Bird Pt5! Back out on the road! Running good! 2 barrels for now, 4 to come! (Mart's Update 2419) When I first got the T-Bird running over 30 years ago I couldn't get the carb to work in it's original state. I had to substitute parts from a later carb and just run on two barrels. Having recently got it running again, I felt it was time to put things right. Or at least try. Follow me in my quest to troubleshoot the original parts and get them reunited with the car. In this video, while it's not running the original parts as I wanted to, at least with fresh spark plugs I get it running well again and was able to get it to the fuel station for fresh fuel. Future videos will show further reinstatement of the original parts plus secondaries and vac advance. https://youtu.be/n6krcPn9Rs0 Last edited by Mart; 04-05-2024 at 10:35 AM. |
04-05-2024, 10:34 AM | #22 |
57 T-Bird Pt6! It runs on 2 barrels. Will it run on 4? Plus remote start and Ruby! (Mart's Update 2420)
When I first got the T-Bird running over 30 years ago I couldn't get the carb to work in it's original state. I had to substitute parts from a later carb and just run on two barrels. Having recently got it running again, I felt it was time to put things right. Or at least try. Follow me in my quest to troubleshoot the original parts and get them reunited with the car. In this video, I make a remote starter switch and make some progress on reinstating the secondaries. I also start looking at the choke. Future videos will show the difference the 4 barrels have made plus the distributor will get some attention to the advance mechanism. I Hope you enjoy this offering. Don't forget: Keep it real! Keep it cheap! https://youtu.be/n8so0vilWWo |
04-12-2024, 10:37 AM | #23 |
Mart's Old 57 T-Bird! Reinstating the choke and Four Barrel Road Test! (Mart's Update 2421)
When I first got the T-Bird running over 30 years ago I couldn't get the carb to work in it's original state. I had to substitute parts from a later carb and just run on two barrels. Having recently got it running again, I felt it was time to put things right. Or at least try. Follow me in my quest to troubleshoot the original parts and get them reunited with the car. In this video, I Get the choke reinstalled and take it for a test out on the road. In a future video I will show reinstating the Vac Advance and replacing the points plate in the distributor. I Hope you enjoy this offering. Don't forget: Keep it real! Keep it cheap! https://youtu.be/8XCrSm9nsfM |
04-12-2024, 02:20 PM | #24 |
Sure sounded good Mart. Music to my ears when the secondaies on a four barrel open up. Even though I'm more used to the quadrajets. I can see you don't get a lot of opportunity to "pedal to the metal" there unlike here.
https://www.youtube.com/user/roosty6/videos |
04-19-2024, 11:17 AM | #25 |
Here's the latest.
Mart's Old 57 T-Bird Pt8! Vac Advance hooked up! More Progress! (Mart's Update 2422) In this video, I show reinstating the Vac Advance and replacing the points plate in the distributor. There then follows a bit of fooling around and a little drive. I Hope you enjoy this offering. Don't forget: Keep it real! Keep it cheap! https://youtu.be/izD0MX3OnnU |
04-19-2024, 03:46 PM | #26 |
04-22-2024, 02:17 PM | #27 |
Mart I am glad to see you got around to hooking up the vacuum advance. That was bugging me!
The more I learn about new automobiles, the more I value my old ones. |
04-26-2024, 11:36 AM | #28 |
Mart's Old 57 T-Bird Pt9! Lots of little jobs! Let's Tinker! (Mart's Update 2423)
In this video I work my way through some small but essential jobs on my old 1957 Thunderbird. I change the air filter which was from when I first got the car going, I play with the bimetallic spring on the autochoke just for fun, I change the oil and filter, look at the accelerator pump and revisit the vacuum line with some new fittings. I Hope you enjoy this offering. Don't forget: Keep it real! Keep it cheap! https://youtu.be/rpc5dbBX104 |
04-26-2024, 05:15 PM | #29 |
Mart: My long gone replica T-Bird 302 with a 5 speed, made by Harry Shay and sold in some Ford dealerships 1979-80 time frame. They made 10,000 model “A” replicas and about 200 T-Birds. Google Shay model A. |
05-03-2024, 10:45 AM | #30 |
Hi Vette. I remember seeing pics of those Shay Birds. There is at least one here in the UK.
This weeks offering: Mart's 57 T-Bird Pt 10! Heater fixed after 20 years! Plus a Minor Accident! (Mart's Update 2424) Back in the mists of time the heater core in the T-Bird sprung a leak. I disconnected the hoses and carried on, as you do. I did pick up a heater core that I thought might fit. In this video, continuing with the theme of fixing long overdue issues I get the prospective replacement in place and working after a couple of glitches. I had a near miss when the car selected reverse unexpectedly. No harm though, so all good. Another little job out of the way. https://youtu.be/ciiEhloIexo |
05-10-2024, 12:32 PM | #31 |
This week's offering:
57 T-Bird Pt 11! New door check strap and latch adjust + small Jobs a plenty! (Mart's Update 2425) Time to address some more small items on the T-Bird. I replace a missing check strap. I adjust the push button on the driver's door handle to get it opening correctly. I put a clevis pin in the door, fit a new fan belt and put an on off valve in the heater hose. All little jobs but each one represents a step in the right direction. Bit by bit the car is getting better. I Hope you enjoy this offering. Don't forget: Keep it real! Keep it cheap! https://youtu.be/Ny4T-EijXfY |
05-14-2024, 02:33 PM | #32 |
Something a bit different this time:
A day out in the countryside! T-Bird +Caterpillar D2 Donkey start! (Mart's Update 2426) My friend Mark holds a get together at his place in aid of charity. I rode down there with Geoff in the T-Bird. I persuaded Mark to start up the little Cat crawler he had there. A fun afternoon with good people and a great place to be. Thanks for the invite, Mark, and thanks for the book too! I Hope you enjoy this offering. Don't forget: Keep it real! Keep it cheap! https://youtu.be/EOaXirGUbDw |
05-17-2024, 12:02 PM | #33 |
Here's tonight's nonsense:
Mart's 1955 100E. Tidying Loose Ends plus Classic cars at Gaydon! (April) (Mart's Update 2427) It was time for the first Gaydon Gathering for 2024. The 100E was the weapon of choice. As it was it's first long-ish run I wanted to change and set the gearbox oil and top up the steering box. I also tackled a slight weep at the fuel tank sender. I used a novel method for the gearbox which went well. I was also able to jack the car up by my rebuilt sill which was good. Had a good run down to Gaydon and checked out the classic cars that had braved the changeable weather. https://youtu.be/mpCHMrkADkk |
05-21-2024, 10:29 AM | #34 |
Hey! This one's on topic!
Mart's 1933 5 Window Coupe: Sitting nearly 3 years. Will it run? (Mart's Update 2428) Hello! Welcome to Mart's Garage. Many will have noticed my 1933 5W coupe in the background. It has been parked nearly 3 years. I decided I would try and run it this year. So join me as I dig it out and see if it will run. The engine is the crusty flatty. The one I featured in a video series a few years ago. Check it out if you want to see an engine that in reality should have been scrapped. https://youtu.be/E9-Pvvb2Dsk |
05-21-2024, 04:04 PM | #35 |
Mart: your running out of vehicles to get running, I think you need a bigger garage
05-24-2024, 11:19 AM | #36 |
Ha ha yeah Vette. If I had acreage I would be dangerous.
Anyhoo. This evening's offering: Mart's 1933 Coupe: It runs! Will it drive? Will it STOP? +100E and Classic Cars! (Update 2429) Many will have noticed my 1933 5W coupe in the background of my videos. In the previous video I got the engine running without too much trouble. In this video I wanted to take it for a run and get some fresh fuel. Well, I didn't make it that far. Join me as I dig into it and try and see what's wrong. As a special bonus I took a trip out in the 100E to a local breakfast meet. Some interesting cars there so check it out! The engine in the coupe is the crusty flatty. The one I featured in a video series a few years ago. Check it out if you want to see an engine that in reality should have been scrapped. I Hope you enjoy this offering. Don't forget: Keep it real! Keep it cheap! https://youtu.be/wa36BF00SLk |
05-28-2024, 10:52 AM | #37 |
Tonight's bit of low commitment escapism.
Mart's 1933 Coupe: New Master Cylinder goes on! But more brake work required! (Update 2430) Many will have noticed my 1933 5W coupe in the background of my videos. In previous videos I got the engine running without too much trouble, and tried to drive it but could tell there was a problem with the brakes. In this video I fit a new master cylinder and go through the rest of the brakes to see if everything else was ok. Guess what? It wasn't! The engine in the coupe is the crusty flatty. The one I featured in a video series a few years ago. Check it out the playlist if you want to see an engine that in reality should have been scrapped. I Hope you enjoy this offering. Don't forget: Keep it real! Keep it cheap! https://youtu.be/aGHJ_x4QIM0 |
05-28-2024, 10:58 AM | #38 | |
05-31-2024, 11:51 AM | #39 |
Mart's 1933 Coupe: Let's finish the brakes and go for a ride! (Update 2431)
In previous videos I got the engine running without too much trouble, and tried to drive it but could tell there was a problem with the brakes. In this video I finish the repairs to the brakes and finally get out on the road for a drive. The engine in the coupe is the crusty flatty. The one I featured in a video series a few years ago. Check it out the playlist if you want to see an engine that in reality should have been scrapped. I Hope you enjoy this offering. Don't forget: Keep it real! Keep it cheap! https://youtu.be/6YBKt1SPLuU |
05-31-2024, 12:51 PM | #40 |
