Old 03-31-2024, 06:58 PM   #1
millersgarage
millersgarage's Avatar
Default modern paint code/mix for 1965 thunderbird interior color?
NOT LOOKING FOR DYE
I am looking to match light aqua interior paint from a 1965 Thunderbird in a modern ppg formula.
I had them try the spectrum analyzer and it could not get a good match due to the texture.
millersgarage is offline   Reply With Quote
Old 03-31-2024, 07:21 PM   #2
KULTULZ
KULTULZ's Avatar
Post Re: modern paint code/mix for 1965 thunderbird interior color?
Can you post the INT TRIM CODE off the PATENT PLATE?
- AT MY AGE, ONE APPRECIATES A STURDY HANDRAIL -
KULTULZ is offline   Reply With Quote
Old 03-31-2024, 07:21 PM   #3
paul2748
paul2748's Avatar
Default Re: modern paint code/mix for 1965 thunderbird interior color?
Call Pat Wilson's Thunderbird Parts in NJ - he may have some information. he specializes in later Tbirds
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 03-31-2024, 07:32 PM   #4
millersgarage
I do not have the data plate, it is an interior that was put into my 51 Mercury from 65 t-bird.
Old 03-31-2024, 08:58 PM   #5
KULTULZ
KULTULZ's Avatar
Arrow Re: modern paint code/mix for 1965 thunderbird interior color?
See if this helps. Scroll down to 1965 -
https://www.thunderbirdregistry.com/...trim-codes.pdf
Old 03-31-2024, 10:41 PM   #6
paul2748
paul2748's Avatar
The formulas and composition of paints have changed so much that the early codes aren't much help.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 04-01-2024, 07:43 AM   #7
Ford blue blood
Ford blue blood's Avatar
PPG was able to provide a perfect match for my 58 Edsel Pacer for my paint supplier. Spend a little time with one.
Bill, certified Ford nut.
2016 F-150
2016 Focus
08 Shelby GT500
57 Ford Ranchero
36 Chevy, 351C/FMX, 8", Mustang II
Ford blue blood is offline   Reply With Quote
Old 04-01-2024, 02:50 PM   #8
dmsfrr
dmsfrr's Avatar
99% sure the color names and color code letters that Ford used only relate to their in-house PR/marketing and documentation. Sometimes paint names were changed in different years even tho the same paint was used.
Example: code "T" Skyhaze Green in '54 is the same paint color as Thunderbird Blue in '55.
And the same 'name' might be used for slightly different paint colors.
Ford paint color names and code letters could change from year-to-year, or not. As the Marketing Dept. could chose to keep things 'new & improved'.
The various paint manufacturers have their own letter/number color formula designations not directly related to the in-house FoMoCo numbers.
As mentioned, the older ingredients may no longer be available, some discontinued by govt regulations.
Old 04-01-2024, 07:26 PM   #9
KULTULZ
KULTULZ's Avatar
Red face Re: modern paint code/mix for 1965 thunderbird interior color?
... whew ...
OP asks a simple question and the GREAT DEBATE starts ...
If I guessed right on the INT TRIM CODE from his color description, the INT TRIM CODE is 27 - LIGHT AQUA CRINKLE ALL VINYL.
Where as a regular auto paint store may not have the info or interest to find the paint code, there are suppliers that specialize in older cars -
READ HERE - https://forums.fordthunderbirdforum....or-code.14913/
FORD bought it's paints and supplies from outside vendors such as PPG - DITZLER. These companies were suppliers to the assembly plants and made the colors to FORD specs.
There is no big mystery.
Old 04-01-2024, 07:32 PM   #10
paul2748
paul2748's Avatar
Try www.paintscratch.com if you have the codes and the name of the color. They may be able to help you. They helped me for a Subaru color that I have on my 54 Ford.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 04-01-2024, 09:14 PM   #11
millersgarage
Here is the Dupont chip book from back in the day
