Old 03-23-2024, 06:11 PM   #11
38 coupe
38 coupe's Avatar
Default Re: 276 stroker from 35 years of parts
I suspect the 8RT cam is either the same as the 8BA cam, or is the older 37-48 grind. I would check the 8BA and the EAB cams for condition and if either are good use them first, with preference on the 8BA cam. No need to spend another $200 you don't need (that will be used for water pumps, gaskets, or some other necessity). Post the journal diameters and we can keep offering opinions. You definitely want good cam to bearing clearances as that directly affects engine oil pressure.
