Old 02-17-2024, 09:22 AM   #1
32Bee
Default 37 Ford Dash Light Switch
I'm trying to find out if the 37 dash light switch operates the same as the 36.
Is the knob in the pulled out position when the lights are off and pushed in
to illuminate the lights?
32Bee is offline   Reply With Quote
Old 02-17-2024, 09:56 AM   #2
terry
Default Re: 37 Ford Dash Light Switch
On my 36, when the dash lights switch is pulled out then the lights are out. terry
terry is offline   Reply With Quote
Old 02-17-2024, 10:24 AM   #3
terry
I think that was changed in 1937. So, if the switch is pulled out then the lights turn on. terry again.
Old 02-17-2024, 10:39 AM   #4
32Bee
Can anyone verify Terry's last statement that in 37 the dash light switch knob is pulled out to illuminate the dash lights?
Old 02-17-2024, 10:50 AM   #5
Terry,OH
Terry,OH's Avatar
The 35 dash light switch operates opposite than the 36-37. The only differernce between the 36 & 37 is the knob.
Old 02-17-2024, 11:47 AM   #6
terry
Sorry about that, 32 Bee. I knew there was a change made at some point but wasn't sure when. It seems more reasonable to have the lights come on when the switch is pulled out.
terry
Old 02-18-2024, 06:38 AM   #7
32Bee
Thanks for your timely response Terry.
Peter
Old 02-18-2024, 09:48 AM   #8
v8fordman
v8fordman's Avatar
This is true. The ‘36-‘37 switches turned the lights off when pulled out. The ‘35 turned them on.
v8fordman is offline   Reply With Quote
Old 02-20-2024, 09:56 AM   #9
Seth Swoboda
Seth Swoboda's Avatar
I've always been curious as to why there was a switch to turn the dash lights on/off? If your headlights are on, wouldn't you want your dash lights on as well?
