Old 01-12-2024, 09:45 PM   #1
Southtowns27
Southtowns27's Avatar
Default Which intake to clear generator?
I'm hotrodding a '49 Merc for my '46 pickup. I'd like to run a dual carb intake, but which one will clear the generator? I can't offset mount the gen because the fan attaches to it. Thanks in advance!
Southtowns27 is offline   Reply With Quote
Old 01-12-2024, 09:51 PM   #2
a36bonanza
Default Re: Which intake to clear generator?
Offenhauser 1075 will work
a36bonanza is offline   Reply With Quote
Old 01-12-2024, 09:56 PM   #3
Rodrelic
Edmunds
Rodrelic is offline   Reply With Quote
Old 01-12-2024, 11:19 PM   #4
Bored&Stroked
Bored&Stroked's Avatar
Run an Edelbrock Slingshot . . . great manifold for a 2-carb street setup. One of the best - period.
Old 01-13-2024, 09:26 AM   #5
pistonbroke
I'm not getting why you can't off set the gen. On my brothers 53 we run a Fenton duce with the gen off set. It's a sweet running little car. You don't mess with the fan at all. Tim
Old 01-13-2024, 09:38 AM   #6
Jack E/NJ
Jack E/NJ's Avatar
>>I'm not getting why you can't off set the gen.>>
>> I can't offset mount the gen because the fan attaches to it.>>
Old 01-13-2024, 11:38 AM   #7
V8 Bob
V8 Bob's Avatar
Any "regular dual" intake, early or late, will allow the stock generator location. What intake are you using now, early or late?
Old 01-13-2024, 11:47 AM   #8
19Fordy
19Fordy's Avatar
Photos would help.
Old 01-13-2024, 01:52 PM   #9
pistonbroke
Yes a photo would help .Not trying to be insulting, If your fan attaches to the slide mount like the original 46 they sell the offset for right or left side that accommodates the fan mount. Same thing for the narrow belt configuration that came later. Tim
Old 01-13-2024, 09:30 PM   #10
Southtowns27
No pics yet because the engine is disassembled and still on the engine stand. I'm beginning to accumulate parts and want to know my options.
Old 01-13-2024, 10:26 PM   #11
Bored&Stroked
Sometimes I take an old generator, take the guts out of it, shorten the middle case to about 3/4" long and make a "shortie idler" for the fan. I take the stock armature, push the plates/windings off of it and then shorten it on my lathe to fit the short case and machine the backend of the shortened shaft to run inside the rear plate bearing. I make sure that I use the stock front and end plates - so there are two bearings to support the shaft.
It mounts in the stock location and solves the fan issue. Then, you can mount the generator off to the side.
