Old 01-08-2024, 11:15 PM   #24
SoCal32
Default Re: Should I convert from 6 volts to 12 volts
As someone that just picked up a restored '47 Sedan that is still 6-volt, my concern was the jump starting if away from home. What's the proper procedure with the positive ground 6-volt system if jumping with a 12-volt source?
SoCal32 is offline   Reply With Quote
