Old 01-03-2024, 10:53 AM   #1
larry harding
Default engine splash pans help needed
i've checked with some local guys, but no one seems to have the 1966 mar-april edition of marc with plans for the dust pans.. thanks to bob johnson for the date of this article. can anyone out there make a copy of this article and snail mail or email it to me. help greatly appreciated.
larry harding is offline   Reply With Quote
Old 01-03-2024, 11:46 AM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: engine splash pans help needed
Larry, are you wanting to see the article so you have dimensions to fabricate a set of engine pans, -or is there more to having that article. I have many old original engine pans that could either be restored or be used to pattern from if that helps.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 01-03-2024, 01:01 PM   #3
larry harding
i enjoy making things for ,my self so i'd like to see the article. i need a set of pans for the speedster i'm building as well as a friend just bought a beautiful older restoration that is missing the pans, so i'll probably be making two sets. i might be into a set of older pans for a pattern if reasonable. ... i just realised we have communicated before , i'm over in h'ville n.c. so if we make a deal i wouldn't mind making a run up there(1 1/2 hr ride +-). let me know or give me a call.... 828-699-1425
Old 01-03-2024, 04:10 PM   #4
Y-Blockhead
Y-Blockhead's Avatar
Didn't someone just post the dimensions in your other thread last week?
Old 01-03-2024, 04:11 PM   #5
Y-Blockhead
Here... https://www.fordbarn.com/forum/showt...ht=engine+pans
Old 01-03-2024, 06:19 PM   #6
larry harding
looked back on my post from a few days ago.... no dimensions or plans i can see , must have been on someone elses post.
Old 01-03-2024, 07:09 PM   #7
Roxo
Roxo's Avatar
engine splash pans
Roxo is online now   Reply With Quote
Old 01-03-2024, 07:36 PM   #8
Y-Blockhead
Plans posted by Bob Johnson in a thread you started 12/31/23. https://www.fordbarn.com/forum/showt...ht=engine+pans
Old 01-03-2024, 09:42 PM   #9
Randy in ca
Randy in ca's Avatar
Strange stuff going on - I also don't see the link to the plans that Bob gave in the other thread - the only place I see the link is if I search for that particular post in Bob's profile. If I quote Bob's #3 post the link to plans is there, yet if I preview that quote the link is not. Weird.
Randy in ca is offline   Reply With Quote
Old 01-03-2024, 09:45 PM   #10
Bob Johnson
Bob Johnson's Avatar
Larry,
It was not in MARC but in MAFCA (Restorer).
Bob Johnson is offline   Reply With Quote
Old 01-04-2024, 07:47 AM   #11
larry harding
thanks guys... i'll ask around about the MAFCA, maybe someone has a copy. if not maybe i will run across a set some time. i've got them on my 31 pickup, but it is too cold outside and a lot of trouble to take them off. the drawings in the post would be hard to work with unless i could blow them up and print them out. i'm barely computer literate so that may not work.
Old 01-04-2024, 10:17 AM   #12
Y-Blockhead
Larry, you can't see the picture I blew up here? How strange....
Old 01-05-2024, 07:59 AM   #13
larry harding
that looks good, but i'm a computer dummy. if i try to print that it wants to print the whole column of posts,not just that one. i printed it out anyway, but it shrunk the drawing a bit. i'll break out some 20 gage ant give it a try. thanks
Old 01-05-2024, 10:56 AM   #14
Y-Blockhead
Larry, what kind of computer do you have. With my iMAC I can just drag the image to my desktop and print full size. It is a JPG file.
Or take a screen shot - on iMAC; hold command - shift - 4 - outline image
Or PM me your e-mail address and I will send you the file?
Old 01-06-2024, 07:45 AM   #15
larry harding
thanks again .... my address is [email protected] as i said i'm no computer nerd, i was getting up in years before i dealt with computers.
Old 01-06-2024, 01:04 PM   #16
Y-Blockhead
I sent you an e-mail with the schematic. Good luck.
Old 01-06-2024, 01:06 PM   #17
Ed in Maine
Larry, I would recommend that you mark the location for the cutout that is for the exhaust pipe to fit your car. I have installed two sets of pans and both purchased sets of pans that had cutouts that were not located properly. Ed
Old 01-07-2024, 09:46 AM   #18
larry harding
many...many thanks to you guys. after some fumbling around and some help from the boss lady i've printed out a readable set of plans. i hope my sheet metal skills are better than my computer skills.
