I would measure the actual throw-out bearing-to-pressure plate clearance by removing the starter plate. You only need about .100" clearance, which should result close to 1" pedal free travel, depending on how you measure. Now you can check for worn/damaged linkage/parts and repair/replace/adjust to lessen/correct excess pedal travel.
