Old 12-25-2023, 05:55 PM   #1
Old Redneck
Old Redneck's Avatar
Send a message via AIM to Old Redneck Send a message via Yahoo to Old Redneck
Default Cutting a Ford Scrip Battery to remove the Optima Battery
I want to cut open a Ford case Battery to remove the Optima Battery. Any of you ever done this? If so how did you do it without destroying the case. The one I have bought is not worth a nickel. The Optima Battery in them is worthless.
Old Redneck is offline   Reply With Quote
Old 12-25-2023, 07:22 PM   #2
52flthed
Default Re: Cutting a Ford Scrip Battery to remove the Optima Battery
Curious why you would want to do that? I have one and it works well. They're supposed to be really good batteries. What kind of trouble are you having with it? Do you want to use the case for something else?
52flthed is offline   Reply With Quote
Old 12-25-2023, 07:32 PM   #3
ford38v8
ford38v8's Avatar
That’s as bassackwards an operation I ever heard of. We cut open Ford Script acid batteries to put in Optima batteries, not the reverse.
Alan
Old 12-25-2023, 08:26 PM   #4
tubman
tubman's Avatar
Reading between the lines, I have to believe that he bought a well-used one that was beyond it's useful life. If that's not it, I dunno; I've had three and they have all lasted more than 10 years (OK, the current one is only 7 years old) and spun the engine over just fine.
Old 12-25-2023, 08:54 PM   #5
expavr
expavr's Avatar
Old redneck
See the attached thread: https://www.fordbarn.com/forum/showt...ry+ford+script
I haven’t taken the time to attempt to replace the Optima in my Ford script case, so I can’t answer your question right now, but your thread has motivated me to get that battery out and see what can be done.
Les Williams
expavr is offline   Reply With Quote
Old 12-25-2023, 11:49 PM   #6
J Franklin
J Franklin's Avatar
A dremel tool with a cutoff blade should do the job.
Old 12-26-2023, 08:57 AM   #7
Old Redneck
All I want to do is to replace the Optima Battery that in the Ford Scrip case with a new Optima battery. They are dry cell Battery. Understand now.
Old 12-26-2023, 11:01 AM   #8
Ken/Alabama
Ken/Alabama's Avatar
I’ve done it twice. Go around the lid with a razor knife. The lid sits down inside the top perimeter of the case. Mine was sealed with RTV. You’ll also need to trim the plastic away from the lead post. They will be stuck to the top. I’ve replaced the optima battery in mine twice. The resealed the top with black RTV.
Old 12-26-2023, 12:45 PM   #9
Model51
Model51's Avatar
Attached is a write-up of what I did to create a Type 40 battery with an Optima inside which is not being reproduced. The optima is taller than the original Ford battery, so the resulting conversion is about 3/8" taller than the original but it still fits beneath the floorboard in my 1935 truck. Other Ford battery types are taller so the conversion can be a lot easier.
1935 157" 1 1/2 ton stake truck undergoing full original restoration
1936 131 1/2" panel truck rescue preservation
Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America
Model51 is offline   Reply With Quote
Old 12-26-2023, 06:52 PM   #10
fordv8j
fordv8j's Avatar
Been wondering the same thing, my Ford script with optima is getting old, will need to replace it soon, sounds pretty easy...thanks Redneck for asking, everything dies sometime
fordv8j is offline   Reply With Quote
Old 12-27-2023, 05:51 AM   #11
DavidG
DavidG's Avatar
I believe that Ken is inquiring about a dead Group 1 script battery from his '32. Those battery cases are too small to contain the 6 volt Optima battery.
Old 12-27-2023, 08:58 AM   #12
Pat/Ohio
Pat/Ohio's Avatar
David, I believe that you are correct in that Ken is referring to his '32.
Just curious...How would you handle this situation? Replace the battery with a regular "tractor type" lead-acid battery, extend the battery tray a little to accept the taller battery or perhaps alter the floorboard a little. All of which would probably mean a point deduction or two (if detected).
I believe C & G Ford Parts in CA is offering the Optima style Ford script battery in their catalog and online. Takes 3 or 4 months for delivery.
Happy New Year!
Pat
Pat/Ohio is offline   Reply With Quote
Old 12-27-2023, 10:56 AM   #13
Cecil/WV
Cecil/WV's Avatar
I, too, like Ken, have a dead Optima in a Ford script case that needs a replacement installed.
Cecil/WV is offline   Reply With Quote
