12-19-2023, 11:50 AM | #1 |
1937 Halogen headlight conversion
I want to do a halogen headlight conversion on my '37 Tudor. Dake sells a kit with reflectors, sockets/pigtails, and bulbs. However, they are out of stock at least through the end of 2024. Does anyone know of any other sources for these?
12-19-2023, 12:31 PM | #2 |
Re: 1937 Halogen headlight conversion
Try Ron Francis Wiring. I have an old catelog but can't find it. terry
12-19-2023, 02:21 PM | #3 |
Check with Michael at Third Gen or some of the other Drake dealers to see if they still have any of the conversion kit.
12-19-2023, 02:47 PM | #4 |
Remember this kit will pull a lot of amps -current. Some components can't handle the amperage draw. Newc
12-19-2023, 02:58 PM | #5 |
12-19-2023, 03:09 PM | #6 |
Cars and metal rust away and are destroyed, but the Word of God will stand forever (Isaiah 40:8, Matthew 24:35). |
12-19-2023, 03:25 PM | #7 |
just curios why not leds lot less current draw
12-19-2023, 05:35 PM | #8 |
I have ordered two sets of LEDs. None of the two contacts on the back of the bulb line up with the original Ford socket. In other words, they don't make contact. If you are familiar with these bulbs they only go in one way.
Is there something I'm missing with the LEDs because they are the cheapest and easiest way to go about this. This is a daily driver car. I do drive at night. Well not the '37 because the original bulbs are not bright enough for safe driving. |
12-19-2023, 06:42 PM | #9 |
Good old back order Bob again . There are conversions on eBay ,but as to quality?
12-19-2023, 08:03 PM | #10 |
I don't know what kind of bulb a '37 takes. But after trying ill fitting LED bulbs off ebay for my '35 Fordor, I ordered a pair of flanged LED bulbs from ledlight.com. They fit perfectly and light up the road very well. I can now run my stock 6v generator at a very low setting and still show a positive charge with the lights on. A great cimbination.
12-19-2023, 08:15 PM | #11 | |
12-20-2023, 09:14 AM | #12 | |
12-20-2023, 11:09 AM | #13 |
12-20-2023, 12:24 PM | #14 |
I had halogen bulbs in my ‘37 when I inherited it. I switched back because the light scattered all over. I found out later that there are lenses just for the halogen lights that do not have the prisms in them. They might work better than the standard lenses.
12-20-2023, 04:07 PM | #15 |
I had an original pair of reflectors nickel plated then sent them to a company in Oregon called Uvira. They do reflective coatings and they turned out very nice and way more durable and cheaper than silver. These were for my 39 Zephyr still 6 volt system. Had bright white headlights with original bulbs.
12-20-2023, 04:08 PM | #16 | |
12-20-2023, 05:44 PM | #17 |
Agreed, I have fitted period relays to my cars. I know that it protects the switch & wiring from burning out and, as stated above assures the brightest of lighting from the bulbs. My '42 Sedan had lights equal to or better than most modern cars with its 6Volt halogen bulbs in semi-sealed beam units. and no need to convert to 12 volts either.
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand http://www.fordbarn.com/forum/album.php?albumid=580 |
12-21-2023, 03:48 PM | #18 |
My experience exactly, meric42.
I don’t trust LED bulbs to last or have consistent quality. Too many have failed me of home and antique auto use. I also prefer the color of halogens/light bulbs and beam pattern than the bluer LEDs.
12-21-2023, 04:02 PM | #19 | |
The parts book show 1935-39 use the same headlight bulb. |
12-21-2023, 06:20 PM | #20 |
My '38 came to me with the Drake halogen conversion (12V). Although not as bright as LED, they match the prism in the lenses and work fine for my limited night driving.
