Old 12-11-2023, 04:28 PM   #1
outsider347
Default lifter bore adj hole
What dia hole suggested in the lifter bore for the adj lifters?
Tks
outsider347 is offline   Reply With Quote
Old 12-11-2023, 04:45 PM   #2
Ol' Ron
Ol' Ron's Avatar
Default Re: lifter bore adj hole
I don't think it makes much difference, I use 3/16 but 1/2" might be alittle big'
G
Old 12-11-2023, 05:29 PM   #3
Bored&Stroked
Bored&Stroked's Avatar
I usually use a long 3/16 drill bit that I get from McMaster Carr. You can't easily get any sort of drill in the valley, so you need an extra long bit.
Old 12-12-2023, 10:01 AM   #4
pistonbroke
I did 3/16's but don't make the same mistake
I did. Drill the holes as low down on the lifter bore wall as possible, about half of mine were just to high so the holding tool wouldn't quite pass into the lifter, Tim
Old 12-12-2023, 10:49 AM   #5
Tim Ayers
Depending on the type of cam you are using, I may suggest scalloping the top portion that faces in towards the valley. With a high lift reground cam, the adjusting screw on an adjustable lifter can sometimes sit below the top of the lifter boss which makes it hard to turn the adjusting screw.
Old 12-12-2023, 11:16 AM   #6
Bored&Stroked
Originally Posted by Tim Ayers View Post
Depending on the type of cam you are using, I may suggest scalloping the top portion that faces in towards the valley. With a high lift reground cam, the adjusting screw on an adjustable lifter an sometimes sit below the top of the lifter boss which makes it hard to turn the adjusting screw.
Good idea! I usually do this as it allows you to adjust the lash with the lifter all the way down on the heel of the cam (which is where you're supposed to do it!).
Old 12-12-2023, 11:20 AM   #7
Bored&Stroked
When you're running longer valves, this also helps one get to the adjuster screws - which is a real pain if you don't relieve the tops of the lifter bores.
Old 12-12-2023, 09:25 PM   #8
outsider347
Thank you Gents.
Old 12-13-2023, 11:46 AM   #9
Ol' Ron
Ol' Ron's Avatar
Remember................ The lifters were made for stock valves and cam. They work well on cams with up to.350 lift. More lift requires the adjusting screw to cume out of the lifter creating a loose condition and noisy lifters. The easy solution is to use the SBC 1.5 valve which is .060" longer. They also make a larger 1.6 valve winch will allow you to repair a bade seat with out using a seat insert .
Gramps
Old 12-14-2023, 11:45 AM   #10
outsider347
Tks Ron
Great info
Old 12-16-2023, 05:13 PM   #11
Karl Wolf
Karl Wolf's Avatar
I have been wondering if these hole could be drilled from the bottom side of the block.
This may involve figuring out where the lifter locates,
while on the back side of the cam lobe,
to make a jig - a drill guide.
Karl
Karl Wolf is offline   Reply With Quote
Old 12-16-2023, 05:16 PM   #12
flatjack9
flatjack9's Avatar
Gramps
Some of the original Johnsons came with a thicker adjuster bolt.
Old 12-18-2023, 04:42 PM   #13
TomT/Williamsburg
TomT/Williamsburg's Avatar
The lifter hole info is great - comparing a stock lift cam to your new cam should give you an idea of where to drill your hole as you look at the groove in your lifter. What I have been taught is to get one intake and one exhaust valve set up with your adjustable lifter and set the rest to that measurement to make your adjustments that much easier/ closer to what you need for the other 7 cylinders. I might be stating the obvious to most who have done builds but I figure I would throw it out there …
TomT/Williamsburg is offline   Reply With Quote
Old 12-19-2023, 09:51 AM   #14
outsider347
Good idea
tis
Old 12-19-2023, 12:24 PM   #15
Newc
Newc's Avatar
I would like an illustration on drilling and dishing bore, so chip cleaning could be done early before assembly. Newc
Old 12-19-2023, 12:51 PM   #16
Ol' Ron
Ol' Ron's Avatar
Another bit of information that might help here. Because I had to do allot of blocks, drilling these holes became a time issue. If one hole was off you had to drill another, and if you had the engine assembled, where would the chips go. been there dine that. SSSOOOOO I took an old distributor shaft drilled a hole in the end and pressed in a short philips driver sharpened to a point. Now the size of the shaft was just right and the hole loation was easy to dril with the long drill. Now this operation only took a few minuts from start to finish. Don't forget to clean the holes.
Gramps/
If I could post pictures I'd post one??????
Old 12-19-2023, 01:34 PM   #17
Tim Ayers
Correct. My engine is all buttoned up. I'll try to find one of the rebuilding books that shows these operations in great detail.
