Old 12-09-2023, 06:20 PM   #11
35fordtn
35fordtn's Avatar
Default Re: 47 V8 ignition mystery
The breaker plate terminals can give issues. We have to check them thoroughly during every rebuild. That usually only causes a random miss. You declined the recommendation of a full rebuild on your distributor and only had us adjust the dwell and timing so there is a lot of still unknowns
Only missing under heavy load only with no relative relation to rpm’s sure sounds like carburetor power valve or accelerator plunger to me
