10-10-2023, 07:59 PM | #21 |
Re: Air Filter or not
I was told over 40 years ago that the air maze air filters were only good for keepin low flying birds out of your engine…..
Also more Model A fires have been started by running a paper element filter hanging off the carb. Sooner or later a leaky carb will give you a gas soaked paper element filter. One backfire and that’s all she wrote…… |
10-11-2023, 11:20 AM | #22 | |
The Master Cylinder Enjoying life at the beach in SoCal... |
10-11-2023, 12:49 PM | #23 | |
Carburetor could be leak free for years and then one day on your way to lunch a tiny bit of gunk from the tank works its way in between the needle and the seat. Before you know it that filter is a ticking time bomb and one unforeseeable backfire could send another Model A to the scrapyard and possibly anyone onboard to the burn ward. |
10-11-2023, 04:15 PM | #24 |
This from Renners Corner unless you modify your carb:
https://www.rennerscorner.com/carbur...formation.html |
10-11-2023, 07:55 PM | #25 |
I do not use a air filter and have not had any issues
10-11-2023, 11:19 PM | #26 | |
I can't even recall the last time my engine backfired
10-12-2023, 08:54 AM | #27 |
So some here think that not having a filter on the motor is ok?
I was always schooled by some good mechanics that it is a good way to shorten the life of a motor. I bet Ford enjoyed it. More business for the dealerships.
1928 Roadster Pickup 1930 Tudor 1943 Ford WWII Jeep 1968 Taco Minibike Member, Santa Anita Model A's Arcadia Ca. |
10-12-2023, 10:52 AM | #28 | |
The idea being as the air was drawn in, the heavier dirt particles would be spun by centrifugal force and exit through a slot or hole on the bottom of the canister. Last edited by AzBob; 10-12-2023 at 11:02 AM. |
10-12-2023, 11:18 AM | #29 |
I use an original AirMaze. If you clean it once a year and then oil it, it collects a LOT of dirt. I have had no issues with it affecting my fuel/air mix. I've ran it for many years.
10-13-2023, 08:47 AM | #30 |
I have been hesitant in posting my experience with an air filter because it does not apply to most Model A's. I run the two barrel down draft Weber carburetor with an air filter. I recently found an air filter that is taller than what came with the car that I believe gives me a little better performance. I also have an electric fuel pump. The Weber is designed to use an air filter. I discovered, quite by accident, that the fuel pump cuts off the fuel flow to the Weber when not being powered. The float bowel for the Weber is below the level of gasoline in the tank so without the cutoff from the pump it could leak if the float valve was damaged or contaminated. So I have quit cutting off the fuel with the valve under the tank unless I want to run the carburetor dry for storage of the car or another reason.
10-13-2023, 09:50 AM | #31 |
10-16-2023, 03:30 PM | #32 |
Last edited by David in San Antonio; 10-16-2023 at 04:51 PM. Reason: tried to delete altogether. Sorry. |
