Old 09-16-2023, 12:36 PM   #1
jkflathead
Default '38 and '39 Banjo Difference?
Which one of these banjo steering wheels is 1939 and which is 1938, based on the center core? Thanks. John
jkflathead is offline   Reply With Quote
Old 09-16-2023, 02:08 PM   #2
petehoovie
petehoovie's Avatar
Default Re: '38 and '39 Banjo Difference?
Old 09-16-2023, 02:56 PM   #3
deuce_roadster
deuce_roadster's Avatar
2 pictures from the top might be better. I have a 38 that looks like the top picture. Are you sure the bottom wheel has not been modified?
Old 09-16-2023, 05:46 PM   #4
jkflathead
It has not been modified.
Old 09-16-2023, 07:12 PM   #5
38 coupe
38 coupe's Avatar
The 38-39 Ford Book states the only difference between the banjo wheels is the little tie bar and the color of the rim with no difference in the hubs.
I remember in a talk given by the author Gary Mallast he said he was surprised when he reviewed the engineering drawings for the deluxe steering wheels and found there was any difference at all between the wheels other than the paint.
I too suspect one of the wheels has been modified, either an original after production, or as a reproduction wheel with a modified design from stock.
Old 09-16-2023, 08:32 PM   #6
jkflathead
I wonder what the core of a standard '38 and '39 look like? The '37 is quite sever in its cone shape at the core. The one that I have that I think is the '38, is also cone shaped but not as sever. The flat one seems to make sense that it is a '39 because the design seemed to be going in that direction. I have studied the pictures in the V-8 Club book. And the tie bar is very similar. Is one of the tie bars noticeable different in size? Thanks for your help.
Old 09-16-2023, 10:24 PM   #7
mercman from oz
mercman from oz's Avatar
1938 Ford Deluxe Banjo Steering Wheel
Old 09-17-2023, 06:54 AM   #8
Dak Rat
I have had many '38 and '39 wheels, there was no difference between the two. The horn buttons are different of course.
Dak Rat is offline   Reply With Quote
Old 09-17-2023, 07:45 AM   #9
38 coupe
38 coupe's Avatar
There is a difference that is so small almost noone notices it. The tie bars ends are more rounded on the 38 banjos and are more squared off on the 39 banjos.
Old 09-17-2023, 08:38 AM   #10
ActionYobbo
ActionYobbo's Avatar
On the top picture It looks like the tie bar is out of position I can see the notch in the wire where it should be
I am building a 1939 1 ton express
ActionYobbo is offline   Reply With Quote
Old 09-17-2023, 09:11 AM   #11
Kube
Super Moderator
Kube's Avatar
1939 deluxe
Kube is online now   Reply With Quote
Old 09-17-2023, 10:10 AM   #12
ford38v8
ford38v8's Avatar
Bingo!
Alan
Old 09-17-2023, 11:39 AM   #13
38convsedan
38convsedan's Avatar
Does anyone have Oyster Gray paint info?
38convsedan is offline   Reply With Quote
Old 09-17-2023, 04:42 PM   #14
fordv8j
fordv8j's Avatar
I think on the 39 banjo wheel the groove in the tie bars had red paint in them
fordv8j is offline   Reply With Quote
Old 09-17-2023, 06:12 PM   #15
mercman from oz
1939 Ford Deluxe Banjo Steering Wheel - Kube
Old 09-17-2023, 06:26 PM   #16
38 coupe
38 coupe's Avatar
The Auto Color Library website at least recognizes the color exists. It appears to the the same information as the 38-39 book. Link here:https://www.autocolorlibrary.com/pag...HorizontalTab3
Old 09-17-2023, 07:43 PM   #17
Kube
Super Moderator
Kube's Avatar
You are correct. The wheel I'd restored, once installed, did receive the red paint in the "bars".
Old 09-17-2023, 11:11 PM   #18
mercman from oz
1939 Ford Deluxe Banyo Steering Wheel and Dash - Kube
Old 10-07-2023, 08:00 AM   #19
jkflathead
I was wrong. This wheel that I have has had the bottom sliced off to fit another kind of column. Does anyone know why somebody would do that? And what kind of column does it now fit. Thanks. jk
Old 10-07-2023, 09:05 AM   #20
42merc
42merc's Avatar
The wheel probably has been "sliced" to more closely match the cup on a '40 & later Ford column.
I have done this in the past.
42merc is offline   Reply With Quote
