08-15-2023, 05:58 PM | #1 |
46 Ford Car Rear brake backing plate removal
Hello! I did a search and couldn't find if anyone has had this situation.
I'm removing the rear axle to replace a pinion bearing and am having trouble getting the rear backing plates off -- I want to take everything apart and clean and rebuild. Specifically my issue is with the bottom front bolt. I've got all 4 nuts off, (which was sort of a chore in itself!), but these 2 bolts wont come out. Same location on each side. I've hit one with a pretty substantial hammer, wont budge! I may have damaged the threads some on one of them. Should I warm up the housing with a torch, or ??? Any suggestions are welcome. Thank you! |
08-15-2023, 06:07 PM | #2 |
Re: 46 Ford Car Rear brake backing plate removal
Try Loosening the radius rod at the front end by removing the bolt that holds the two together.
08-15-2023, 06:54 PM | #3 | |
08-15-2023, 06:59 PM | #4 |
OK, will do! maybe I can wiggle it off. Let you know. Thank you!!
08-16-2023, 01:30 PM | #5 |
Ken, thanks for the help! That did the trick
08-16-2023, 02:18 PM | #6 |
