08-11-2023, 11:00 PM | #1 |
1930 e brake return spring
Anyone have instructions on how to install the e brake handle return spring?
08-12-2023, 07:31 AM | #2 |
Re: 1930 e brake return spring
Are you referring to the spring inside the handle that makes the button pop back up after you stop pressing down on it with your finger?
08-12-2023, 11:04 AM | #3 |
For the handle itself, not the button.
08-12-2023, 11:36 AM | #4 |
When I pull the e brake to put it on, the handle is loose and when I go to disengage it, I have to push the handle forward manually to get the e brake off. I assume there was a spring to pull the handle itself into the off position without me having to push the handle forward.
08-12-2023, 12:04 PM | #5 |
The ebrake rods have springs on them. They pull the rods and lever back to normal. No separate return spring for the brake lever.
I noticed the harder I work the luckier I get! |
08-12-2023, 12:32 PM | #6 |
08-12-2023, 06:23 PM | #7 |
There are also coil e-brake return springs that mount on the rear backing plates that push the e-brake levers back there toward the release position. Plus the springs on the e-brake rods themselves.
If you don't have it already, get a copy of Les Andrews' Model A Mechanic Handbook Vol. 1, the red cover. This is your best place to look first. After that, look in the reprints of the Ford Service Bulletins. https://www.mafca.com/cart/index.php?productID=166 In addition to the springs, make sure that all of the bushings are lubricated so that everything springs back to the released position.
