Old 08-06-2023, 01:05 PM   #1
roncol1957
Default 59ab 80 over cam bearing
First time posting but been reading for a few years. I am having a machine shop build a 59ab for my 36 5window and got the call I needed 80 over cam bearings. I been searching for about three weeks and read all articles I could find and in one it listed NOS part numbers as 01A-6261-D and 01A-6262-D and I found these numbers for sale and I purchased. Now the boxes have D2 instead of D at the end of the part number. Does anyone know what the 2 stands for? Could it be a different ID?
roncol1957 is offline   Reply With Quote
Old 08-06-2023, 02:24 PM   #2
Kube
Super Moderator
Kube's Avatar
Default Re: 59ab 80 over cam bearing
The "2" indicates the part was sourced from a different supplier. It is interchangeable with the same basic number (D).
Old 08-06-2023, 03:14 PM   #3
roncol1957
Thanks
Old 08-06-2023, 03:44 PM   #4
Tim Ayers
I hope the machine shop is really trying to say you need .20 under bearings. If they ground that much off of the journals, I would be very concerned about the shop and you will need a new cam.
I've only seen .20 under bearings for sale. I've seen anything above that.
Tim Ayers is online now   Reply With Quote
Old 08-06-2023, 03:47 PM   #5
19Fordy
19Fordy's Avatar
.20 inches is a lot of metal. Shouldn't it be .020?
Old 08-06-2023, 03:52 PM   #6
Tim Ayers
Thank you, Jim. Yes. .020
Old 08-06-2023, 06:20 PM   #7
38 coupe
38 coupe's Avatar
Ford made and used cam bearings for most combinations of standard, oversize holes in the block as well as undersized journals on the cam. Make sure your bearings match the combination of specifications you need for your block and cam.
Old 08-06-2023, 06:30 PM   #8
Bored&Stroked
Bored&Stroked's Avatar
If they're saying you need .080 oversize cam bearings, then they must be talking about the cam bearing bores in the block. Ford didn't like to scrap things, so I've heard they did over bore certain blocks for special oversize cam bearings (instead of throwing the block away). They obviously made oversize bearings for situations like this.
I've never had a block with oversize cam bearing bores . . . but the day is young! LOL
If you cannot find the bearings, they may need to make them from aluminum bar stock.
Old 08-06-2023, 09:53 PM   #9
barnfind08
I have these cam bearings for years and still do and sold many
barnfind08 is offline   Reply With Quote
Old 08-06-2023, 11:35 PM   #10
cas3
Fred to the rescue again!
Old 08-07-2023, 07:03 PM   #11
roncol1957
Fred, could you PM thanks, roncol1957
Old 08-07-2023, 10:06 PM   #12
V8COOPMAN
V8COOPMAN's Avatar
"roncol" ...... Since you only have a total of 3 posts here on the F'Barn, you're not eligible (YET) to send or receive PMs. Ya need 10 posts to qualify for PM privileges. I have posted "barnfind08" (Fred Wilner's) contact info BELOW ..... you're going to have to contact him. Fred has nine buildings stocked with NOS old Ford parts, plus he is one of our own members here on the 'Barn. Fred is a GOOD guy!!
Coop
Fred Wilner - (barnfind08")
SOUTHSIDE OBSOLETE
7136 200th St E.
Faribault, MN 55021
(507) 332-6789
Click Links Below __
T5 W/TORQUE TUBE
Old 08-08-2023, 06:00 AM   #13
roncol1957
thanks, i will give Fred a call today
Old 05-29-2026, 11:10 PM   #14
duncrd
Barnfind08-i am now in same place as this fellow was in 2023. I am in need of .080 over cam bearings for 59AB build. I finally ended up with good block after 3 unusable ones. Cylinder bores cleaned up at .040 over then the F1 durabond cam bearings too small. Any help is greatly appreciated.
Thanks
Ron
duncrd is offline   Reply With Quote
Old 05-30-2026, 07:09 AM   #15
alchemy
alchemy's Avatar
Just pick up the phone and call him.
alchemy is offline   Reply With Quote
Old 05-30-2026, 07:36 AM   #16
KiWinUS
KiWinUS's Avatar
I have them if Fred doesn’t.
Old 05-31-2026, 10:54 AM   #17
Bored&Stroked
While I've never had a block with the cam bores like this, I'm sure the day will come . . . if I live long enough! I just picked up a pristine 'keystone' 41/42 Merc/WWII 239 block - STD bores, no apparent cracks (had been magged with new cam bearings installed), super clean decks, etc..
I will have the block cleaned again and magged, then I'll pressure test it. Hopefully all is well with it as these blocks are very hard to find.
Old 05-31-2026, 01:05 PM   #18
Newc
Newc's Avatar
Canada Ford was making WW2 Military engines '38 to '45, I have a '41 in my Canadian Merc. Factory relieved with a 3 3/16" bore. Newc
Old 05-31-2026, 03:19 PM   #19
big job
big job's Avatar
Chrysler prod. was famous for odd bearings too. Also Fred is the man!
big job is offline   Reply With Quote
Old 05-31-2026, 04:37 PM   #20
Ronnieroadster
Ronnieroadster's Avatar
So far after being involved in hundred's of flathead engine's I never came across any oversize cam bearing bores. Could it be possible during a short period of production the boring process for the cam bearing bores were machined incorrectly being to large a bore for the standard cam bearings. This would then be the reason for the needed oversize OD cam bearings. Makes one wonder why.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
