#21 |
Here is a picture of the inside of my case looking towards the rear. Is the slinger installed backwards on mine?
#22 |
"It don't take but country smarts to solve the problem" (Smokey Yunick) '30 Model A Speedster '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302
#23 |
The pic above is one posted by Lawrie a while back. Should be correct...he's very good at this stuff.
#24 | |
#25 |
#26 |
If you remove the U-joint and the rear bearing retainer along with the rear bearing the slinger should come out and can be reversed. Note there is a double metal shielded bearing to replace the rear bearing just remove the inner shield so trans oil can reach the bearing internals, this will stop the leaking. Make sure the snap ring on the perimeter of the rear bearing is .075" thick and not much thinner. The helix teeth in your transmission main shaft do differ from the teeth on Lawrie's. Yours is good and a different year than Lawrie's. |
#27 | |
#28 |
As noted, the slinger is in backwards. It is probably causing MORE oil to go through the bearing, not less.
You MIGHT be able to get the rear bearing out without pulling the transmission but be very careful that you don't pull the main shaft backwards with it. I've never attempted to change this bearing while the transmission was in the car - have found it easier to just pull the engine and trans as a unit. I hate trying to work on these things when they're in the car - total pain in the rear in my mind. I can have the engine and trans out of my 32 in about 2 hours - but I've also done it a few times! ![]() ![]()
#29 | |
Thanks for your guidance |
#30 |
UPDATE…
The info I received from this post was invaluable. I ended up removing the engine and tranny together, opened the gear box and found that the transmission rebuilder before I bought the car actually installed the slinger backwards. To compound things, they beat it into the back of the case with a standard screwdriver. I replace the slinger and rear bearing with a sealed bearing. No leaks. It was a big job, but I’m so happy I took the time to make the repair properly |
#31 |
Thanks for the update, glad to hear it resolved your issue.
