Old 08-02-2023, 07:35 PM   #1
Alaska Jim
Alaska Jim's Avatar
Default rochester 2g's on a Y-block edelbrock 3x2 intake
Has anyone tried to adapt the Rochester 2g carbs to an Edelbrock 3x2 intake manifold. I am curious if it can , or has been done. I am tired of fighting these Holly 94 carbs, and their sensitive fuel pressure problems and the temperamental vac. signal problems. Anyone, anyone have any thoughts?
Alaska Jim is offline   Reply With Quote
Old 08-03-2023, 07:04 PM   #2
paul2748
paul2748's Avatar
Default Re: rochester 2g's on a Y-block edelbrock 3x2 intake
Make some adapters out of aluminum ???
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 08-03-2023, 09:00 PM   #3
Alaska Jim
Alaska Jim's Avatar
Paul, if I go ahead and try this , that will be the way I go. My brother is a machinist, and has his own mill, and lathe.
Old 08-03-2023, 09:45 PM   #4
40cpe
40cpe's Avatar
I assume you are considering the older, small base 2G. Check to see if there is room for three on the manifold. With almost twice the flow of a 94, two should be plenty on a mild engine.
Old 08-04-2023, 12:02 PM   #5
Ole Don
Ole Don's Avatar
If you can still find the small 283 size, they make a wonderful carb for a three two intake.
Ole Don is offline   Reply With Quote
Old 08-04-2023, 12:53 PM   #6
Alaska Jim
Alaska Jim's Avatar
40cpe, and Ole Don. Yes, the older 2g from an early 283 with the small throttle bore's are what I had in mind. The spacing on the manifold may be the only problem.
