08-02-2023, 04:08 PM | #1 |
Turn signal problem
Indicator light does not flash, but is faintly glowing all the time! Turn signals work as expected when lever moved.
I have this in my ‘29 Town sedan. No problem for many years, until recently. Please offer suggestions for troubleshooting. I have used 2 different signal switches. I have tried to find a short but to no avail. I would appreciate re-guidance to be certain that I have tested properly. Any sites where shorts are prone to develop? All suggestions for testing will be appreciated and executed. |
08-02-2023, 04:17 PM | #2 | |
Re: Turn signal problem
www.whidbeymodelaclub.com |
08-02-2023, 04:56 PM | #3 |
Bad ground probably on the steering column
Sent from my iPhone using Tapatalk |
08-03-2023, 07:04 AM | #4 |
I agree with the ground comments, plus, I've found some of the switches packed full of grease causing this issue.
08-03-2023, 01:11 PM | #5 |
Comments appreciated.
I've wondered about the grease, but I didn't know how to fully remove it and if the grease is the problem I'd assume it must be totally removed. I have tried to check all wires in and out for grounding to no avail. The turn signal switch is connected to the cowl via a separate wire. I don't know how to interpret the observation that the P line from the flasher = 5.9V when disconnected from switch but 1-2 V when connected and the light is glowing. When the switch is turned on, there is a variation of 5-2 V in that line when connected. This variation is coincident with the lights blinking. Also, I didn't note, but the indicator light is never blinking despite the fact that the signal lights outside are just fine. |
08-03-2023, 03:45 PM | #6 |
08-05-2023, 11:33 PM | #7 |
People still use turn signals?
08-06-2023, 01:26 AM | #8 |
