272 started making what i thought was a manifold leek, so i poured tranny oil down the carb and the smoke exposed the leek at exhaust manifold wich is now fixed .
noise still there i can rev engine 3500 rpm in neutral , NO NOISE then soon as i let clutch out and put motor under load noise appears and is obvious when acccellerating |
spark knock? timing?
It's probably not the engine. I would suspect one of the u-joints or transmission. Do you have the bottom flywheel cover installed on the bellhousing? It's not a good idea to drive without that because a rock can fly up in there and get kicked around by the flywheel.
How are the motor mounts? If under load and the motor rocks, it can open up an exhaust leak that is not there when not under load.
it was at 12* i pulled it back to 6* still ticking
u joints seem ok next is motor mounts ... |
I once had a tick on my 56 292 that finally turned out to be one of the rocker arm shaft mounting bolts loosened up allowing too much clearance on the rocker arm assembly. Listen at the valve cover to see if that can be eliminated.
Matt 24:36-41 |
I would think you would hear it at idle speed also if either a loose rocker shaft mounting bolt or a woefully loose adjusted rocker arm. He said it makes no noise at idle.
yes and i even blocked the wheels with emergency brake on and loaded the motor " no ticking" only while driving
i'll check rocker shafts
Only when driving takes the noise to behind the flywheel. Those U joints may seem OK, but I would bet the price of a U joint that one is bad.
ok ill yank the drive shaft
stay tunned |
#13 |
Tell ya what. Leave that flywheel bottom cover off and drive down a few dusty roads. That flywheel acts as a fan blowing dust right at the starter drive. It'll be no time and your starter drive will be stuck in the disengaged position.
#14 |
Put car on jackstands under the rear axle. Run it in gear, accelerate while applying brakes to load the engine. Have a helper listen under hood (or elsewhere) to locate the noise.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick) '30 Model A Speedster '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302
#15 |
I’ll put cover on when I’m sure rear main is not leaking on my refreshed 272
Off to check u joints |
#16 |
drive shaft is off
everything is free ,smooth and no slop so i greased it now reinstalling so now its to run car on jack stands or check rocker shaft and make sure its tight to the head ... |
#17 |
drive shaft is ok
rocker shaft and valve lash is ok i'll have to get help to run it on stands |
#18 |
Are you sure it is not "pinging", caused by poor fuel octane, or incorrect ignition timing? This only happens under the conditions you described.
#19 |
sounds like a manifold leak , i'll go at it again tommorow
i'm at 6* maybe pull a bit more timing out i only use premium pump and i've put a few tanks recently |
#20 |
have a manual choke? if not set choke part way closed and retry. If you don't hear the noise it's running lean.
