06-11-2023, 05:17 PM | #1 |
Flathead powered roadster drag racer
we are getting ready for an event called the No Name Nationals in Sikeston, Mo. in Sept. So we have been going to test n tune a few weekends in a row now. It's down to 8.76 in the 1/8 mile. Also have a new 360 degree camera that I have just started to play with. If anyone is so inclined please check out my youtube channel. thanks
https://www.youtube.com/watch?v=n0Y0pk__0vU |
06-11-2023, 05:31 PM | #2 |
Re: Flathead powered roadster drag racer
Cool stuff - thanks for sharing! What are the specs on your engine?
06-11-2023, 06:08 PM | #3 |
Hi Dale, 3.268 bore x 4.25 stroke, Ross pistons, Schneider .425 lift cam, Offy heads, Kong intake with two Holley 4412's mounted sideways. T5 transmission with .79 5th gear and 4.88 gear.
06-11-2023, 07:34 PM | #4 |
Neat stuff.
I assume you will soon solve the stuck in first gear problem.....(just kiddin') |
06-11-2023, 08:07 PM | #5 |
I did miss third on one run at test n tune!
06-11-2023, 08:32 PM | #6 |
See you in August Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
06-12-2023, 04:10 AM | #7 |
Thanks Phil . . . was just curious. It has a pretty small bore - did you do that just to ensure that it can be bored a few more times?
06-12-2023, 10:15 AM | #8 |
I had talked to the guys that run the Thompson Door Car at Bonneville and they were running a supercharged flathead that was running 195mph in a modified roadster, so I figured they knew what they were doing, and they said they ran a small bore to keep the wall thickness up. Latter I purchased some stuff from Harry Sternemann including a block and the pistons that they had run in a lakester that ran over 200 mph and actually the pistons were even smaller at 82mm.
06-12-2023, 10:17 AM | #9 |
Oh, and the pistons, crank and rods were all used stuff from our Bonneville car.
06-13-2023, 10:29 AM | #10 | |
https://www.loringtiming.com/ |
06-13-2023, 02:33 PM | #11 | |
Also testing the Scotty's roadster with Supercharged ARDUN another 200 MPH combination its extremally loud. Ronnieroadster
06-13-2023, 04:21 PM | #12 |
Sounds like great fun. I'm going to try to get up there.
Glenn |
