Old 06-03-2023, 06:23 PM   #1
Dirtslinger
Default King bearings 8ba rebuild
New to the forum and looking for some help with my 8ba rebuild. I managed to get a NOS French 4" crank and will be using it in my motor. There's a seller on Bay selling new STD King main bearings, should I use these or go for Clevite?
Dirtslinger is offline   Reply With Quote
Old 06-03-2023, 07:47 PM   #2
Shoebox
Shoebox's Avatar
Default Re: King bearings 8ba rebuild
Do a search on KING bearings, many positive comments. I've used them in my current 276 engine build.
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is offline   Reply With Quote
Old 06-03-2023, 07:50 PM   #3
Ken/Alabama
Ken/Alabama's Avatar
King Bearings from what I’ve experienced are quality bearings.
Old 06-03-2023, 08:22 PM   #4
Ronnie
Ronnie's Avatar
They are a player in the bearing business.
Ronnie
Ronnie is offline   Reply With Quote
Old 06-03-2023, 08:40 PM   #5
Ol' Ron
Ol' Ron's Avatar
King bearings are very good and quite expensive. Considering the application soare stock bearings, All bearings must be fit to the crank, have good oil pressure. You pay your money and make your choice. Never used them.
Gramps
Old 06-03-2023, 08:46 PM   #6
flatjack9
flatjack9's Avatar
Never had a problem with them.
Old 06-03-2023, 09:59 PM   #7
cadillac512
cadillac512's Avatar
Good bearings. I put them in my 260" Merc 22,000 miles ago. They were in spec and of high quality, no complaints at all.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 06-03-2023, 10:25 PM   #8
Dirtslinger
Great. The Clevite option is actually more expensive than King currently. There is a seller on Ebay selling the Kings for $110, are there lots of counterfeits going around today?
Old 06-03-2023, 10:43 PM   #9
tubman
tubman's Avatar
King Bearings are (were?) made in Isreal for use in the flathead-powered French military trucks favored by the Isreali army. Thus, they are "mil-spec" and of the highest quality.
Old 06-03-2023, 11:44 PM   #10
Dirtslinger
Gramps
When you say fit to the crank, do you mean turning the journals? This crank is standard, what would you suggest I do? The crank is currently at the machine shop getting cleaned and polished.
Old 06-04-2023, 06:54 AM   #11
cadillac512
The main and rod bearings for an 8BA type engine are precision fit and if the crank is standard or a normal undersize no custom fitting will be necessary. Checking with Plasigage is always a good idea, but you should have no problems at all.
Terry
Old 06-04-2023, 07:10 AM   #12
Tim Ayers
I also used King's. No issues.
Old 06-04-2023, 08:56 AM   #13
3twinridges
3twinridges's Avatar
I think Reds sells the kings.
JB
3twinridges is online now   Reply With Quote
Old 06-04-2023, 12:14 PM   #14
Ol' Ron
Ol' Ron's Avatar
I do agree the King bearings are very good, however, I didn't feel it was ncessary to spend the extra money for them in a street engine. True if everything is machined correctly, there is no fitting the bearings, However, When bulding a preformance engine for street or track, our clearances become more important. Putting a set of rod bearings into a rod and torking them to specs and checking the bore dia. will give you the information for the crank grinder to gove you the clearance you want. Same for the mains. I like .0025, It's worked for me for many years
Now Florters are another story!!!
Gramps
Old 06-04-2023, 04:11 PM   #15
tubman
tubman's Avatar
Gramps
That's one reason I'm an "8BA Guy".
Old 06-04-2023, 06:57 PM   #16
Shoebox
Shoebox's Avatar
Ditto.
32 Ford roadster
39 Mercury Towncar
