Old 04-23-2023, 07:58 PM   #1
blueoval37
blueoval37's Avatar
Default V8 60 Build Help
I'm restoring original 37 with 60. I plan on edelbrock heads and intake 2 81s. Looking for someone with experience building the 60 to go through this motor. Ran when I got the car. Took heads off has .30 over pistons looks like a recent rebuild when parked. Car sat 58 years in Montana barn. Anyone help me in the right direction. Prefer Midwest builder though if anyone knows of one. Can crate and ship if I have too. Any help appreciated Thanks Mike
37 Ford Slantback 60hp. All steel nut and bolt restoration in process. Period correct hot rod.
Boling Brothers Lincoln Brakes
39 Pedals
Van Pelt Built 3spd
HotRodWorks Banjo Rearend
blueoval37 is offline   Reply With Quote
Old 04-23-2023, 08:08 PM   #2
Pete
Default Re: V8 60 Build Help
You might try locating Rich Willim's son. He used to be on this forum. I think he was in the midwest. Rich wrote a V860 book.
Old 04-23-2023, 08:27 PM   #3
Lanny
Lanny's Avatar
Maybe this will help ???
Early Ford V-8 Club Forum
Early Ford V-8 Club of America
https://www.earlyfordv8.org › forum › viewmessages
Dec 10, 2021 · 1 post · 1 author
This description is from Richard Willim's book, "The V8-60 Ford's Little Powerhouse".
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 04-23-2023, 08:33 PM   #4
blueoval37
blueoval37's Avatar
Thanks guys I will definitely check out that swap its about 3 hours away
39 Pedals
Van Pelt Built 3spd
Old 04-24-2023, 06:26 AM   #5
KiWinUS
KiWinUS's Avatar
I can and probably have every part you may need. I’m in Charlotte NC if you can’t find anyone closer. Good luck either way. Cheers. Tony
Old 04-24-2023, 07:01 AM   #6
blueoval37
blueoval37's Avatar
Thanks Tony I appreciate it. I think it's an easy build but you never know. I already have most things rebuilt for the motor but need it internally done. I'm in the process of building an offset 60hp generator bracket to run the aftermarket multi-carb intakes. I'm going to run the Powermaster Powergen shorty. The alternator in the generator case.
39 Pedals
Van Pelt Built 3spd
Old 04-24-2023, 07:36 PM   #7
KiWinUS
KiWinUS's Avatar
Just let me know if I can help and what your timeframe is. Thanks.
Old 04-24-2023, 08:13 PM   #8
flatjack9
flatjack9's Avatar
Rich Willem is in Michigan. He's on Facebook. I'm in Oshkosh, Wi and would like to help, but I'm swamped with work.
Old 04-24-2023, 08:18 PM   #9
blueoval37
blueoval37's Avatar
Thanks I appreciate it. I'm hoping to start build in about 3 months.
39 Pedals
Van Pelt Built 3spd
Old 04-25-2023, 11:09 PM   #10
JM 35 Sedan
JM 35 Sedan's Avatar
Unfortunately, Rich Willim passed away some years ago. His son Marty Willim posts on Facbook and is also quite knowledgeable on these little 60hp engines. He has been selling some of the parts his dad accumulated over the years.
The book on the 60hp engine that Rich Willim wrote is no longer being printed, but I see them coming up for sale on line occasionally. It's definitely worth owning if/when you find a copy.
One of Marty Willim's Facebook posts:
https://www.facebook.com/groups/7187...ibextid=Nif5oz
John
Old 03-24-2024, 07:59 AM   #11
Brillman
Brillman's Avatar
Hey im in need of some v8 60 parts
Brillman is offline   Reply With Quote
Old 03-24-2024, 08:06 AM   #12
KiWinUS
KiWinUS's Avatar
What?
