04-21-2023, 02:26 PM | #1 |
TCP global, any good?
TCP Global is selling off a lot of paint right now. I want to buy some Brewster green acrylic enamel, $ 179. a gallon, Is the stuff any good? like to hear some of your results with TCP, good and bad?
Terry |
04-21-2023, 03:10 PM | #2 |
Re: TCP global, any good?
Only used epoxy primer. Ok for price
Prefer PPG but my goodness what a price for ppg |
04-21-2023, 04:10 PM | #3 |
I'm painting my 31 roadster brewster green now took the model A chip book to carquest and they matched the color, i like it , in the shade looks black and in the sun dark green.
04-21-2023, 04:13 PM | #4 |
I CAN GET THE CODES off the cans IF YOU WANT them.
kurt |
04-21-2023, 08:18 PM | #5 |
Terry,
You get what you pay for. No bargains with paint, cheaper stuff uses more material to get coverage. This is why you should always use a primer close to the color of your top coat. jb |
04-21-2023, 08:54 PM | #6 |
04-21-2023, 09:58 PM | #7 |
04-21-2023, 10:05 PM | #8 | |
Terry |
04-21-2023, 10:11 PM | #9 | |
Terry |
04-22-2023, 08:58 AM | #10 |
I've used TCP acrylic enamel a few times. Color match not spot on, but the product worked very well.
04-22-2023, 03:46 PM | #11 |
Had very good luck with them. I purchased some paint for a set of Z28 wheels. The color was spot on and the paint was good. Very satisfied with them.
04-22-2023, 11:38 PM | #12 |
I have painted more vehicles and boats than I would have preferred to and have used TCP Global on many of them. The Restoration Shop urethane looks good on older cars and goes on fine when mixed 4:1:1 using slow reducer and waiting 45 minutes in between coats at 70 to 80 degrees with minimal air circulation. No solvent pop and very little orange peel when spraying 3 to 4 light to medium wet coats at 29 PSI.
Wait 8 hours, sand what's needed with 2000 grit wet paper then 3000 while it's still soft and then buff it out. Doesn't take long for their paint to get hard as a rock and more difficult to sand. On things I don't really need to sand and buff or I if I want extra depth I'll use TCP urethane single stage paint and spray two medium coats then spray a third coat with 25% TCP clear coat, (hardener and clear coat), blended into 75% mixed color paint, (color, hardener and reducer), followed by a fourth coat of 50:50. Won't be as smooth as cut and buffed paint but it's good enough for the girls I go out with. For the price I don't think TCP can be beat. |
04-23-2023, 01:38 PM | #13 |
I’ve used them a few times and never had an issue. In the paint world you get what you pay for. That being said, If you’re looking for a budget paint job, the paint sprays decent and lays out fine. If you’re looking for a nice flat job, you’ll probably need to wetsand and buff.
