Old 04-14-2023, 04:49 PM   #1
Detonator
Detonator's Avatar
Default Topped off trans -- now synchros are glitchy
My '35 coupe has a '39 trans and a '40 banjo, both newly rebuilt. I've put somewhere between 50 and 100 miles on the car. Today I climbed underneath and topped off the trans. I'm running Lubriplate SPO 288 in both the trans and the rear end. I added oil it it until it just started to come put the fill hole.
Now...my 2nd gear synchros are glitchy. It'll only downshift to 2nd at walking speed. The synchros worked fine before topping off. I put a few miles on it to warm things up, but it didn't help much.
Is it the gear oil? I read in an earlier post that Lubriplate SPO 277 was a better oil for newly-rebuilt trans/banjos. Is this my problem?
Seabright Hot Rods
Detonator is offline   Reply With Quote
Old 04-15-2023, 07:07 AM   #2
joe 1950
joe 1950's Avatar
Default Re: Topped off trans -- now synchros are glitchy
In all my years working on old cars trucks whatever i have always kept the oil below the filler hole at least one inch you’ll still have plenty of lubricant ,to full causes foaming good luck
joe 1950 is offline   Reply With Quote
Old 04-15-2023, 07:10 AM   #3
joe 1950
joe 1950's Avatar
Just to add one more thing what’s wrong with using 80-90 gear oil with a little lucas oil supplement works great for me thank you
Old 04-15-2023, 07:53 AM   #4
Gene1949
Gene1949's Avatar
Certainly appears you have the right product.
I've had very good luck with CRC Sta-Lube API/GL-4 Multi-Purpose Gear Oil 85W90 in both the 49 Ford (T-10) and the Camaro (Muncie)
Neither liked the more modern oils and acted "glitchy" when shifted. That being said both transmissions using that oil were cranky until warmed a bit.
Gene1949 is offline   Reply With Quote
Old 04-15-2023, 07:59 AM   #5
alanwoodieman
what number GL?
Old 04-15-2023, 10:02 AM   #6
Zeke3
Zeke3's Avatar
The SAE grade of the Lubriplate SPO 288 is 250, which sounds way too viscous for an old Ford transmission. The SPO 277 with an SAE grade of 140 is more in the range of where you want to be.
Zeke3 is online now   Reply With Quote
Old 04-16-2023, 11:06 AM   #7
Detonator
Detonator's Avatar
I’m pretty sure that’s my issue. I picked up some GL4 140 yesterday and will drain and refill in the next day or two. I’ll report back. Thanks.
Seabright Hot Rods
Old 04-16-2023, 11:33 AM   #8
Newc
Newc's Avatar
Napa sells GL-1 for old transmissions. GL-5 is supposed to attack brass? Newc
Old 04-16-2023, 02:02 PM   #9
Detonator
Detonator's Avatar
True. GL-4 doesn't attack yellow metal.
Seabright Hot Rods
Old 04-16-2023, 02:12 PM   #10
Fritz
Fritz's Avatar
I second Sta-lube 85-90. Gl-4. Good for yellow metals in your trans. My 2nd gear likes that a whole lot better than the 85-140 I had in it. Second gear holds and doesn’t pop out anymore. The Sta-Lube is good trans oil. Don’t use bud light.
Cars and metal rust away and are destroyed, but the Word of God will stand forever (Isaiah 40:8, Matthew 24:35).
Fritz is offline   Reply With Quote
Old 04-17-2023, 08:35 PM   #11
Detonator
Detonator's Avatar
I swapped out the Lubriplate for a GL-4 140W. It gets warm here so I didn’t go for the 85-90. The difference in shifting is remarkable. Lots smoother. Thanks.
Seabright Hot Rods
Old 07-15-2023, 05:43 PM   #12
Ward
600 wt gear lube works well . Stock
Ward is offline   Reply With Quote
Old 07-24-2023, 01:30 PM   #13
Andy
I put Tractor Supply Gl-1 in my 32. The improvement was tremendous. It says for Ford transmissions.
Andy is offline   Reply With Quote
