Old 03-15-2023, 08:46 PM   #1
Gold Digger
Default Oil Filler Tube
Just rebuilt engine and now it blows oil out the filler pipe when driving 50 mph. Ordered a oil breather set up to mount on filler pipe but just wondering what caused this problem when it didn't do it before. Also was wondering if a filler pipe and lid from a B model would stop this problem. My filler pipe has some baffels in it but the lid doesn't have anything inside it.
Gold Digger is offline   Reply With Quote
Old 03-15-2023, 08:50 PM   #2
ChicagoBob
ChicagoBob's Avatar
Default Re: Oil Filler Tube
Probably the new rings haven't seated yet, allowing more blow-by than usual. The problem should abate with some more miles.
ChicagoBob is offline   Reply With Quote
Old 03-15-2023, 11:11 PM   #3
Y-Blockhead
Y-Blockhead's Avatar
Did you re-install the filler tube the correct way. The baffles should be installed pointing in a certain direction. Refer to the Service Bulletins, Ford changed them several times in an effort to keep oil from escaping out of the tube.
Old 03-15-2023, 11:23 PM   #4
Tom Endy
Tom Endy's Avatar
My grandson's 30 Tudor did the same thing after the engine was rebuilt. It turned out the breather pipe was from a 28 and it looked like someone had messed with baffle flutes. The engine rebuilder suggested we install a breather from a 32. All the suppliers were out of stock with the reproductions . We obtained an original from Sammy (a good guy to do business with) at Arizona Vintage. When installed it, it did the trick.
Tom Endy
Old 03-15-2023, 11:28 PM   #5
Richard in Anaheim CA
Richard in Anaheim CA's Avatar
I agree with Chicago Bob. Put some more miles on it. Vary the speed and load the rings both under load and against compression.
Don't ever put anything inside your filler pipe. It will build up crankcase pressure and the oil will go out the rear main.
Throw an old gym sock over the cap and tube. It will catch most of the mess and just throw it in the trash and put on another when it starts to drip or when you want the engine to look nice.
Richard
Anaheim CA
Richard in Anaheim CA is offline   Reply With Quote
Old 03-16-2023, 02:37 AM   #6
Ivan in southeast va.
Ivan in southeast va.'s Avatar
Buy small black dress socks.
Ivan in southeast va. is offline   Reply With Quote
Old 03-17-2023, 10:14 AM   #7
Bob Bidonde
Bob Bidonde's Avatar
This slide may help you:
Bob Bidonde
Bob Bidonde is online now   Reply With Quote
Old 03-17-2023, 10:33 AM   #8
Gold Digger
Thanks everyone for the information. I'll make sure the baffels are turned right and use a sock till it stops slobbering.
Old 03-17-2023, 02:35 PM   #9
dennis lumbert
dennis lumbert's Avatar
I had the same problem with my rebuilt engine several years ago,I had a B fill pipe and cap so I installed it and solved the problem. Its still on there with no leakage.
dennis lumbert is offline   Reply With Quote
Old 03-17-2023, 04:31 PM   #10
Dick M
Dick M's Avatar
Send a message via Yahoo to Dick M
Several after market filler pipes were made incorrectly resulting in the problem you have. To be sure, I would call Steve at Bert's Model A and get the correct one. It could also be as stated above; this problem may go away after a break in period.
Dick M is offline   Reply With Quote
Old 03-17-2023, 06:20 PM   #11
Gene F
Gene F's Avatar
I have heard of the B-tube and cap thing before, but have never tried it.
Old 03-17-2023, 06:56 PM   #12
MNFATS
MNFATS's Avatar
I had the same problem a few years ago. I put a plastic CHORE BOY inside the cap and that solved the problem for me.
MNFATS is offline   Reply With Quote
Old 03-18-2023, 01:22 PM   #13
ldreeg
ldreeg's Avatar
I have some originals if you decide to go that way. Need month and year of build to get proter one. Larry
ldreeg is offline   Reply With Quote
Old 03-24-2023, 04:59 PM   #14
redmodelt
redmodelt's Avatar
The brass/copper chore boy would work too. Either of which would be pores enough not to get plugged up.
Old 03-25-2023, 09:30 PM   #15
Synchro909
Synchro909's Avatar
Wow, if the rebuild is so fresh that the rings haven't seated yet, it shouldn't be driven at 50 mph, IMO.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
If I am not in trouble, I've done something wrong.
Old 03-26-2023, 09:58 AM   #16
Will N
Will N's Avatar
Yup. My rebuilder said keep it under 35 for the first 300 miles. I took her out for a 20 mile ride each evening and went up and down hills, coming on and off the throttle. You don't want a steady throttle for long periods of time until the rings seat.
Will N is offline   Reply With Quote
Old 03-26-2023, 10:22 AM   #17
JayJay
Same here, works like a champ.
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan (under reconstruction)
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
