Old 06-09-2011, 01:43 PM   #9
Oldmics
Default Re: 57 T-Bird Distributor Codes
Well,any dizzy you put in wont be correct so I would also consider the 1957, 292 tach drive unit also.
Part #s you are looking for are
B7S 12127 A / on the housing it would read FEJ 12127 A or FEJ 12127 A2
B7S 12127 D / on the housing it would read FEK 12127 B or FEK 12127 B2
Units stamped with the "2" were usually a replacement part sold over the Ford parts counter.
Part #s were the same for Mercury engines using a tach distributor setup.
Oldmics
Oldmics is offline   Reply With Quote
