Old 01-26-2023, 08:12 AM   #21
Tim Ayers
Default Re: 47 outer door handle sagging
Originally Posted by deuce lover View Post
Try Southside Obsolete in MN.Fred might have one.
I came to say this. More than likely, Fred will be able to help you out.
Old 01-26-2023, 01:42 PM   #22
Seth Swoboda
Seth Swoboda's Avatar
Originally Posted by Lawrie View Post
Graig , welcome back, we have missed you and your travels,
Lawrie
Lawrie,
How'd the '34 do in the mud? Did you get stuck pulling the travel trailer?
Craig, do a blog about the Colorado trip please.
Seth
Old 01-26-2023, 01:59 PM   #23
Old Henry
Old Henry's Avatar
Bingo! Fred has one.
Way better than trying to fix mine.
Thanks for the tip.
Prof. Henry (The Roaming Gnome)
"It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness
Old Henry is offline   Reply With Quote
Old 01-26-2023, 04:44 PM   #24
Ol' Ron
Ol' Ron's Avatar
Yes, missed riding with you and the dog, hope he\s doing well.
Gramps
Old 01-26-2023, 06:24 PM   #25
Lawrie
Lawrie's Avatar
Seth,
Yes the 33 got stuck towing the caravan, it took me 5 hrs to get it out with some help from a friendly farmer, took ages to clean the mud from the under side later.
But had great fun.
Lawrie
Old 01-26-2023, 07:38 PM   #26
Tim Ayers
Thanks for the tip.
Excellent. Please post more picts of your trips out west. I use them for inspiration.
Old 01-26-2023, 10:10 PM   #27
baceves
baceves's Avatar
Had the same issue on my 47 Ford. I just swapped out the driver side door handles and put on the passenger side and put the passenger side on the driver side. It corrected the problem on 3 out of the 4 door handles.
baceves is offline   Reply With Quote
Old 01-27-2023, 01:35 AM   #28
Lawrie
Lawrie's Avatar
will do, next trip is sometime in feb, but Allas will be in my 28ccpu, this time I will be roughing it, only taking a tent and cooker,
Lawrie
Old 01-27-2023, 07:32 AM   #29
A bones
A bones's Avatar
Say Craig, just recently we were talking about you.
Glad to hear from you.
Sorry you met the deer. Never fun that.
I'm sure you will make Henry's handle right.
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 12-26-2024, 11:53 AM   #30
Clrascoe
I know you this is old thread but any advice on how to put a new spring in place will be appreciated. I got the old spring out as detailed above but getting the new one in place is a challenge. I am replacing the smaller upper spring. 47 car. Thanks
Clrascoe is offline   Reply With Quote
Old 12-26-2024, 02:24 PM   #31
Karl Wescott
Karl Wescott's Avatar
There have been several threads which go into better detail (use the search function to find them) but basically sometimes you can get a spring out and replaced without dis-assembling the latch. Usually the latch has to be partially dis-assembled. When bending tabs for dis-assembly first heat them red hot with a fine flame torch, bend to dis-assemble, heat again and anneal, re-assemble. Failure to heat to relieve stress and anneal will often result with a broken tab.
Karl Wescott is offline   Reply With Quote
Old 12-26-2024, 10:32 PM   #32
19Fordy
19Fordy's Avatar
Old Henry: Welcome back! Now that you have the OEM replacement buy the spring kit and try to repair your old one. It's not that difficult to do.
https://www.ebay.com/sch/i.html?_fro...latch&_sacat=0
Old 12-27-2024, 11:16 AM   #33
Drbrown
Drbrown's Avatar
Same here - good to see you surface. An old timer fixed my '47 coupe door handles by switching them one side to the other - guess the shafts were worn on the bottom side. Rest of the assembly was ok. Regardless, it worked for me.
Drbrown is offline   Reply With Quote
Old 12-29-2024, 09:32 AM   #34
325w
In the old boxes of springs you might find the spring retainer. Used if you break the tabs. Bought springs from vendors that didn’t know what the u shaped parts were for. Wished I had bought all those tabs.
325w is online now   Reply With Quote
