Old 01-20-2023, 04:14 PM   #1
cederholm
cederholm's Avatar
Default temp and oil pressure gauge
I was poking around Mike's A's and saw their coolant temp and oil pressure gauges.
What engine/cooling modifications need to be made to use them?
cederholm is offline   Reply With Quote
Old 01-20-2023, 05:13 PM   #2
nkaminar
nkaminar's Avatar
Default Re: temp and oil pressure gauge
There is a tap on the starboard side of the engine, below the distributor, that can be used to sense oil pressure. The temperature sensor must be screwed into the goose neck (coolant outlet). A goose neck with the proper tapped hole is available from the vendors, see
https://www.snydersantiqueauto.com/p...4021&cat=41737
Old 01-20-2023, 05:21 PM   #3
Y-Blockhead
Y-Blockhead's Avatar
The drilled water outlet is out of Stock at most vendors.
Old 01-20-2023, 07:16 PM   #4
Ray in La Mesa
I used a stock gooseneck, just drilled a hole on the back side (towards the firewall), tapped some threads for the sending unit fitting and JB welded it in. The gooseneck is a bit thin there so be careful. I have seen some sending units that are a bit long & will bottom out on the front side so check your clearance before drilling the hole. You can back the fitting a thread or two then JB it. Some fellows put it on the side but it is in the way of torqueing the head nut there.
Ray in La Mesa is offline   Reply With Quote
Old 01-20-2023, 07:53 PM   #5
Ernie Vitucci
Ernie Vitucci's Avatar
Good Evening...Vintage Precision makes a nice neck with a good thermostat. I've been running one for a few years and really like it. Ernie in Arizona
Old 01-21-2023, 08:52 AM   #6
cederholm
cederholm's Avatar
Very helpful info all. Thank you!
Old 01-21-2023, 09:29 AM   #7
cederholm
cederholm's Avatar
Thanks for the tip - they look to have high-quality parts. I like that!
Old 01-21-2023, 10:46 AM   #8
CA Victoria
CA Victoria's Avatar
Stewart Warner makes a vintage “Wings” gauge in black or white. I have used them in several cars. I don’t have a picture of one in my A but here is what I mounted in my 35 pickup recently.
I used a SW temp only in the A, I felt loosing oil pressure was a rare occurrence and temp monitoring had the greatest value. I was trying to avoid dash clutter so I mounted the gauge on the drivers side kick panel and it looked natural.
Because you are in the colder part of the USA the upper neck with a thermostat mentioned in post #5 may be a consideration.
File Type: jpg 193BEBFF-3CE6-42F3-AC92-F3D26FAB21E7.jpg (66.3 KB, 72 views)
File Type: jpeg 85E9D36E-B5A1-4919-B462-7CA71CAE1EEF.jpeg (21.8 KB, 27 views)
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 01-21-2023, 10:50 AM   #9
Bob Bidonde
Bob Bidonde's Avatar
Hookup of temperature gauge sensor:
File Type: jpg 190A Temperature Gauge Sensor Cable Routing 399kb.jpg (75.6 KB, 103 views)
Bob Bidonde
Bob Bidonde is online now   Reply With Quote
Old 01-21-2023, 02:03 PM   #10
cederholm
cederholm's Avatar
Awesome, thank you. …and agreed about the temp.
Old 01-21-2023, 02:04 PM   #11
cederholm
cederholm's Avatar
The pics are helpful - thanks!
Old 01-21-2023, 05:08 PM   #12
Herb Concord Ca
I have the Vintage Precision Thermostat on both my A's. Best you can get.
Herb Concord Ca is offline   Reply With Quote
Old 01-21-2023, 07:27 PM   #13
shew01
shew01's Avatar
That is what I use—I like the placement of the thermostat close to the head. It’s a little pricy though.
http://www.vintageprecision.com/prod...ing/index.html
Old 01-22-2023, 09:06 AM   #14
Brendan
Brendan's Avatar
I had to take a second look at the gaudges , that looks very similar to my 36 pickup
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 01-24-2023, 03:04 PM   #15
ModelA29
ModelA29's Avatar
I've got the neck with the thermostat and a vintage looking gauge. Always runs at 160.
ModelA29 is offline   Reply With Quote
Old 01-24-2023, 03:47 PM   #16
mcgarrett
No oil pressure gauge, but here's my Rex-a-co temp gauge. I found a nifty steel gauge cup on Amazon which fits it perfectly and used the same hose clamp holding my turn signal switch to tie it down on the steering column. I like that it sits up high where it's easy to see instead of under the dash. Neat and clean.
Old 01-24-2023, 08:14 PM   #17
cederholm
cederholm's Avatar
So glad I asked. Really helpful info all. I like that Vintage Precision piece. If it’s American made I’m ordering one!
Old 01-24-2023, 09:05 PM   #18
cederholm
cederholm's Avatar
Which gauge is that? Looks great.
Old 01-24-2023, 10:02 PM   #19
ModelA29
ModelA29's Avatar
https://www.summitracing.com/parts/h...BoCyKsQAvD_BwE
It's in a mount from Bert's
https://modelastore.com/index.php?ro...roduct_id=4868
Here's the thermostat mount
Old 01-26-2023, 12:52 PM   #20
burner31
burner31's Avatar
What is the point of an oil pressure gauge on a non-pressurized oil system?
Keith
Shawnee OK
'31 SW 160-B
