12-22-2022, 04:10 PM | #1 |
Mechanical brake(s) floaters?
Thank you all again for your replies re 'original mechanical brakes'. Regarding floaters for ’33, the only supplier that I’ve found = Ecklers, Mac’s#, and it is “discontinued”. Firstly, are there suppliers ‘out there? Secondly, Are floaters necessary?=85% braking surface I’ve read. Thirdly, Are floaters unnecessary, but great if you install them? One can ‘lock up’ mechanical brakes? (I never could!) THANK YOU. |
12-22-2022, 06:47 PM | #2 |
Re: Mechanical brake(s) floaters?
Floaters are a big improvement. Flathead Ted a
Member on here has great floaters. I can lock all 4 sheet 60 miles an hour in my 36 with rod brakes. They work fantastic. |
12-22-2022, 08:06 PM | #3 |
12-22-2022, 08:16 PM | #4 |
Like kiwi said they will lock up all 4 wheels , they work well
12-22-2022, 08:20 PM | #5 |
[QUOTE=KiWinUS;2190938]Floaters are a big improvement. Flathead Ted a
Member on here has great floaters. I can lock all 4 sheet 60 miles an hour in my 36 with rod brakes. They work fantastic. KiWinUS: The following users were not found: Flathead Ted. This is my result upon messaging him here on Ford Barn. Thank you. |
12-22-2022, 08:25 PM | #6 |
12-22-2022, 09:13 PM | #7 |
Try FlatheadTed, no space, as his username. I think Snyder’s Model A parts may offer his floaters.
12-22-2022, 09:40 PM | #8 |
12-22-2022, 09:43 PM | #9 |
01-21-2023, 01:27 PM | #10 |
Floaters work and are easily installed
