Hey guys! Sometime in the future I want to purchase a '54-'56 Ford.
Are the power steering units on these cars very troublesome? If so, are they more trouble than they are worth? Thanks - F F
1952 Ford F1 !956 Fairlane Club Sedan 1965 Falcon Sprint 2007 Mustang GT |
Same ones used on the 53', except a different crankshaft pulley and mounting bracket. I love the one on my 53' Merc. The main issue is the seals, correct that and my experience is that you are good to go for years.
https://www.fordbarn.com/forum/showt...RhwPUGJ1GqEwv0 |
Ford stopped using it on full size cars in 65 but continue to use it up to the fox body era on intermediates and compacts. Even used it on Lincoln Versailles. Many complain about the system, I never saw their reasoning. I believe early Corvettes used a form of the same system. My last car with it was a 68 Montego, zero problems in the 205K miles I drove it. Drove nice, not twitchy just relaxing ride. There is 1 zerk fitting were the control valve hooks to the pitman arm often overlooked on grease jobs and 1 on the control valve that is often over lubed on a grease job. Best to do them yourself.
Same basic factory system in my wifes 1970 Cougar
Since the early '80's, I haven't had to do anything to mine except replace the pump-to-control vale pressure hose (which started to crack from old age) and started dripping a little puddle on the driveway. It's an everyday driver, so I doubt you'll find a system that trouble-free.
Once back in the '90s, I burned up an old PS pump on a '57 Ford during a non-stop 50-mile trip. When I went to leave, the engine wouldn't crank. IU got out two 9/16" wrenches and loosened the pump adjustable mount enough to pull the V-belt off the pump. Got back in the car and it started right up and I drove home with standard steering no problem. But that was an original pump never having been rebuilt and had a lot of miles on it. |
#7 | |
#8 | |
Why in the world would someone want a SATURN electric steering system in an early FORD? I could maybe understand RESTO-MOD (and that would be MUST II rack retrofit). - ONE BAD CASE of UGLY-
- POST MOVED TO CORRECT THREAD - TO WIT - Just Wondering (As I Often Do) ... Has anyone thought of what happens when an ELECTRIC ASSIST PS SYSTEM FAILS OR LOSES POWER? I know on a FORD ELECT ASSIST RACK, when you have a service failure or lose power, there is no assist. It's AAA TIME. And how much AMPERAGE does it take to operate a system properly? Think that 30A 6V GEN is going to do it? At least with the BENDIX LINKAGE SYSTEM, you still have manual steering if there is a system failure.
***** "Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'." ― Charlene Darling (Daughter of Briscoe Darling) |
#10 | |||
I'll try to answer your questions the best I can. It's funny because I was intrigued by an article that covered EPS installation into an older car and bought my '54 just because I wanted to try the swap for myself.
See my second point. |
What does a person do about shifter linkage and horn when going electric? I never read much into the articles about the retro fits as I didn't have any interest at the time.
In my case, floor shift and Cal-Custom steering wheel w/pushbutton horn.
#13 |
Thanks for answering, it's as I suspected.
#14 |
I appreciate your explanation.
#15 |
My 55 power steering system shuddered on tight turns when first acquired and leaked a bit (bound to happen after 60+ years), but after a rebuild it's been great. never even give it a thought anymore.
Also my Saturn was unstoppable, so.... *shrugs* |
#16 | ||
I understand the SATURN system is different in design. But a failure concerns me, especially if a woman experiences it. While still using the 1957 OEM STR BOX, you will go back to STD STR with a hydraulic failure but you are now entering a second box of sorts that may increase the difficulty with steering effort. Quote:
Sorry, I just don't understand why.
#17 |
There’s been a lot of discussion about power steering lately. One caution I would add. Lots of parts are interchangeable but workable. The pumps, mounts, hoses, etc. But the drag link is different at least between the Thunderbird and the pass car. I don’t know the interchanges 54 and 55-56. But those drag links are hard to come by and not cheap, and they contain the valve that controls the ram. Take that into account when making your decisions about which way to go, and what you should buy to start with.
#18 | ||
Also, no women will be driving my '54! Quote:
No problem! I had heard about a Saturn conversion and wanted to see if I could make it work in a '54. I love doing that kind of stuff. On my roadster I made body panels from washing machines, used Land Rover trailing arms on my 8" and modified a Kia trailing arm into a panhard bar on the same 8" rear. I don't really care what manufacturer the piece is from, just as long as I can make it work.......cheaply! |
#19 | |
Imagine a 98lb woman having one go unassisted. There is your freezing. What you are trying to do belongs on another style form IMO. H.A.M.B. would be perfect and there are more there into what you are attempting to do.
#20 | |
Imagine a 98lb woman having one go unassisted. There is your freezing. What you are trying to do belongs on another style form. H.A.M.B. would be perfect and there are more there into what you are attempting to do.
