Originally Posted by OldDad
'39 splits in the middle, earlier frames split in the lower half. So the one you currently have is likely a '37-'38 replacement. Any '37-'39 will fit either car or truck.
With respect, what you have posted is the opposite of what is true. ‘37 through part of ‘38 split in the middle while later in ‘38 through end of production ‘39 splits with the lower section being shorter than the upper. All frames are interchangeable in the windshield opening. Check the ‘37 and ‘38/9 restoration books.
