So, the 32 roadster made its first legal road ride in 60+ years. Seems to run OK lower end but not up top. Tops out around 55 with some sputtering. The fuel pressure is to high so we are in the process of putting in a regulator. But also need to at some point look at syncing the the stromberg 97's which have been rebuilt by a guy who's been doing this for a few decades. On syncing them, is the Edelbrock uni-syn useful? Also, any better option?
That's the type I use they work perfectly for syncing multi carb set ups.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587 |
I prefer the snail type, they tend to be more sensitive and accurate
http://https://vwparts.aircooled.net/Snail-Type-Syncrometer-Carb-Sync-Tool-GERMAN-SK-p/ste-sk.htm |
#5 | |
Snail Type Syncrometer Carb Sync Tool, GERMAN, SK Model
Glenn |
#7 | |
ABSOLOUTLY, it is useful. I know of no other way to tune multiples without one. My work car 25 years ago was a big headed duel quad 355 chev stuffed into a 73 Vegas. Light flywheel and a Muncie. Only way to tune 2 500cfm progressive linked AFBs |
The Uni-Sync pictured above is what we used in the late 70's on our Corvair 14oHp, on mine and my brothers Vw's with dual Delorto's and dual Solex's and a neighborhood friend for his porsche 912....It's been the "standard" (I think) for years!!!
I believe the uni syn works good with consistent results. Do read instructions for adjustment since placing the unisyn over the Carb should not bog the engine and still give a reading on the float, which does not have to be between the indicating lines.
I have used the UNISYN for many years with excellent results....it is a very useful and dependable tool for multi-set ups. It is absolutely necessary in setting up a multi-carb intake, or a Hilborn sack injector.
Uni Syn works great for equalizing air flow using the built in manometer. However, and a big "however" is the old ones from back in the day, (70's) are terrific. However later on there was a China knockoff one that looked exactly like the real one (still said "Uni-Syn" in big letters)but would not work at all. To get a reading it choked off the airflow enough to screw up what you were trying to do.There was a guy that took one of the cheap ones apart and measured everything and it was all just like the real one but just would not work. Never did figure out why but it did not work and choked off the airflow that it was trying to measure. Uni-syn got a bad reputation from the junk ones. If you have a really old one, use it. If it looks like a real one but has lettering on it saying "China" throw it away so no one else can try to use it The one shown above says :Taiwan". so I do not know how well it works. I have used my original Uni-Syn on many Porsches and they work great. Twin carbs 6 barrel carbs and 6 stack fuel injection systems etc Just get a real one. I have no problem with made in China in general , but junk is junk wherever it is made.
#12 | |
#13 |
I bought one .It was junk.
#14 |
Old standard for British Su work- find an old unit. Newc
#15 |
I was looking at getting a new one a couple months back while researching my dual carb setup, and most of the reviews were not positive.
#16 |
Saw this thread and recalled looking into this a couple months back. Ordered this vintage one off of eBay yesterday.
#17 | |
#18 |
My old one (from the 60s) doesn't say TAIWAN on it anywhere like the one in the picture. It has always worked for me. Last used it on a pair of 81s on my 32 5w. It wasn't from Edelbrock either.
#19 |
Here’s another one on eBay which is the same as the one I purchased, but in better shape with the original packing and instructions. I found it after searching for the US Pat # 2,858,697. The ad on eBay says this version was produced from 1959 to 1962.
https://www.ebay.com/itm/127499885209 |
#20 | |
