12-05-2022, 10:08 PM | #1 |
Vin help needed please--55 fairlane
Hi All,
Im in the process of purchasing the above car. I have a copy of the ownership, but the numbers dont fit the format of VINs Ive seen listed here. The VIN is listed as 473CK5544726 and am unable to find a decoder that can give me info. I live in Ontario Canada if that helps. Thanks in advance. |
12-06-2022, 06:08 AM | #2 |
Re: Vin help needed please--55 fairlane
Is it a FORD of CANADA car?
If so, you will need either a FORD of CANADA PARTS CATALOG or WORKSHOP SERVICE MANUAL to break it down.
- WANNA SEE A GOOD CAR WRECK? - https://www.youtube.com/watch?v=5oO226PgSkg KULTULZ - HAS MOVED ON TO THE HAPPY PROVING GROUNDS |
12-06-2022, 08:38 AM | #3 |
12-06-2022, 10:25 AM | #4 |
That is definitely not a serial # for a US built '55 Ford. Has to be Canadian or overseas production. I assume you're using the number on the top line of the serial # plate on the side of the cowl inside the driver's door. The same # will be stamped on top of the passenger side frame rail about where the bumper brackets bolt on.
12-10-2022, 12:25 PM | #5 |
It looks Canadian but my experience is only for trucks so I can't help with the manufacturing plant code. There weren't that many plants in Canada so The C is still only known for "Canada" as a general rule but they usually did list the plant the vehicle was manufactured by.
4 = V8 (no listing for CID) 73= 4-door car The C and K I can't tell you for sure. All trucks were built at Oakville, Ontario in that time frame and that's the only one I know the code for. Cars were built elsewhere. The K may be a date code (month) with 55 being the year of manufacture. This would make the 44726 the consecutive manufacturer's linear serial number for that type if what I've mentioned so far has any credibility. Canada always did things a little bit differently. Last edited by rotorwrench; 12-11-2022 at 11:53 PM. |
12-11-2022, 10:28 AM | #6 |
1955 FORD FAIRLANE 1967 FORD MUSTANG CONV. |
12-11-2022, 04:56 PM | #7 |
73c is a 4 door town sedan K is Kansas City build other numbers and letter do not fit the vin pattern last 5 numbers would be the assembly order
12-12-2022, 12:30 AM | #8 |
After further research, the 73C is the Fairlane Town Sedan (more chrome trim). The K comes up as the code for Oakville, Ontario. 55 is likely the year. There should be some other information on the body tag about trim & paint.
The USA built cars ha e a different coding that is a bit more specific but codes changed between 1955 & 56 so there is muddy water in some cases. US produced cars are still easier to find information about. |
12-12-2022, 11:22 AM | #9 |
A photo of the serial number plate would help.
